As others have said the 3D printed latch covers work for the V2. I printed and used rear covers for rear and side covers for side. Printed in PETG with the recommended settings on thingiverse. Thanks again @espinoza700
Glad you are getting some use out of the design! I printed my fist set out of PLA and the backers warped in the Colorado sun, even just on warm mush winter days. PETG is holding up well though.
Enjoy!
Looking good, hope you like them!
I picked up a couple of the Alu-Cab covers to try out. They are a little too large to use under the lock as a gasket, but they fit right around the lock if you trim off about 1mm with an razor knife. For me, both VHB tape and RTV sealant did not stick to the rubber that Alu-Cab used. I have had better luck after I roughed up the rubber with sandpaper and used ShoeGoo.
How exactly did you fix the inner tubes to the latches?
I second this option!!!
Just ordered some of the official GFC latch covers that they just dropped to fix this problem on mine
