WTB beef racks or other mounting brackets
We are also working on side mount awning brackets. These will mount to the slots of the GFC, Rack or wedge tents.
Is this for the V1 or the V2?
Correct, my mistake.
Hi @ALoffroad ,
Any chance these will work at the back of a V2?
I’d like to mount my Shadyboy awning off the rear to cover the tailgate area.
GFC brackets appear to require a shim (at the least, and maybe a trim) and the Lietner brackets don’t appear to be as close fitting as I would like.
Cheers
Wow, @Reggie, please post pics of your setup if you get this going. A Shadyboy off the back sounds perfect for how we use our GFC. @Trout first got me turned on to Shadyboy awnings with their Jeep Gladiator setup.
They do fit on the back between the locks, but if I remember correctly they might need to be shimmed out a bit. Was a while ago when I checked so I don’t remember positively. Mine is on the passenger side but I almost put it on the back.
I’ll update if I get it figured out.
That’s great to hear.
When you were test fitting were you using the GFC brackets?
And on a V2?
Cheers
Exactly, GFC brackets and V2.
I will have to make a shim plate like the crossbars
Thanks for the update! Could you ship with heavily zinc-ed fasteners to prevent galvanic corrosion?
@ALoffroad … Hello, Any updates on the V2 brackets for the Wumbo Bars? I have the V1 modified to fit my V2 ( We’ve spoken on facebook and on other forums)
Kyle
I should have the bracket for the V2 on Dec. 17th from the powder coater. I will get them out to you as soon as they come in.
Awesome!.. it is a great product and I’ll be more than happy to snap some pictures for your use on the website once that comes in!
How did the V2 wumbo brackets turn out? Shipping soon??
hey doc I’ve got 3 beef racks for sale $175/piece. Standard black angus
Received the Wumbo bars and brackets just in time for Christmas! Pics to follow.
There’s nearly 2mm of clearance between the load bearing boss feature on the 1/4"-20 T-nuts and the mounting plate from @ALoffroad . Sloppy. Fabrication method appears to be plasma cutter. I’m disappointed.
6 months later - but finally got it sorted.
Posted here:
Thanks! Made it happen:
