3rd Brake Light Wiring- Rivian
@HighVoltOverland Gave us the original and most thorough Rivian wiring guide. However, more recent Rivian software updates have given us a simpler path. I believe my method will impact Driver+ functionality (Gen 1), but I haven’t tested it yet.
Disclaimer: I am NOT an expert an automotive electrical anything. I figured this out through trial and error. You should trust me with electrical advice about as much as you should trust a toddler working in your main electrical panel. Please speak up if you see something dumb I did so everyone can learn from it.
I wired the brake light into the trailer connector.
Parts needed:
  1. 7 pin to 4 pin trailer adapter
  2. 4 wire trailer cable, 60"
  3. Brake Stop Light Converter. I used an AT-LC-8N
  4. An assortment of connectors, zip ties, etc.
Step 1:
Connect the 7 pin adapter to your Rivian. Fish the 60" 4 pin cable to the trailer hitch area. Use a coat-hanger or something to push the wire through Connect everything.
Step 2:
Cut the other end off your 60" cable. Wire together the trailer wire, the converter, and your brake light. I used shrink wrap connectors.
Wiring goes like this:
Trailer hitch green → Converter Green
Trailer hitch yellow → Converter Yellow
Trailer hitch white → Converter Black AND brake light black.
Trailer hitch brown → cap this off
Converter red/white → brake light red
Step 3: Tuck things away and make it pretty. I think I need another zip tie to tighten this up a bit, but you get the idea.
