Any plans to wrap the exhaust with exhaust tape? i know its right by the truck’s exhaust so its already hot in that area but I’ve seen how some f them get red hot due to the material they use
For anyone interested, that heater setup was developed and is sold by Yona Adventure Gear. I believe the owner said he was opening the website up tonight for additional orders as he just got through his backorder. He’s also developed a “Tent Vent” as a passthrough for the tent portion.
I had sent a join link to the owner, not sure if he ever joined. I do know that he’s also trying to sell his current setup and possibly grab a used V1 for his Tacoma.
A lot of people don’t think it’s safe to have an all in one in an enclosed space. You want the heater’s exhaust to go directly out with any connection made outside to avoid a leak inside.
The trailer is a BADAC trailer, they are made in OK. My buddy lived in one with his family for something like 8months traveling the country. Everything he learned during that time is put into these trailers.
Curious if anyone has had any clever hot air routing ideas with heater in bed but air directed into the tent portion. (Besides removing a cushion or heater outside with hose into tent window/door which seems common).
I was actually thinking about making a duct that would come up into the short end of the wedge. Don’t really need much padding up there so a flat duct that has a 3 inch quick connect through the floor and a wood or metal (both) duct about 2 inches tall 8 wide. Maybe one on the other side as well or shorten a pad for return air…
I have a V1 that has a “factory” hole in the front platform - semi tempted to put a small hole in each front corner and make a cushion that has corners lopped off to allow the air to pass through. Though I’d need to ask them if that poses any kind of large structural threat I guess. Some of those CDH come with a heat outlet pipe with 4 small ports - could pull two off and feed them to the corner holes.
Btw anyone know what that hole is for that came on the front left of the V1platforms?
Brainstorming ways to get heat directly into the top without one of the squares pulled out. What about making a couple of 4 inch holes near the outside edge and porting through with a 4 inch PVC flange (as pictured) so I can just have the 3 inch hose come in and up when needed otherwise it’s just small hard open area where you don’t usually put your body… or it becomes a yeti bottle holder at night…v
My thought here is to cut through the cushion and install this through the cushion and fabric. Kinda like this but instead of a cupholder it’s a passthrough
Looking at it it may even be better to put it on the tall tent side near the corners. If using the passthrough just have that corner be the cold air return and the other the warm air. (My fridge is on the driver so that would be my hot air side and the passenger side the return)
