That’s commitment! No going back once you’ve cut the hole.
If I am going to f stuff up I am going to do it all the way haha
Love it! Thanks for the reply. I was chuckling and nodding in agreement.
Planning on ordering a 2kw heater next week. I guess i have some reading to do in this thread.
I want to build or use a sort of tire table to put the heater on, and use my bed cubbies to route the hvac into the bed
That’s actually the first reason ive seen to buy one of those tables
I like the step more actually. Thanks for that! And the price is much better too. Just need to see if the heater/box will fit when i get it built.
Worse case scenario I have an aluminum folding table that i can put it on
I dig that.
What kind of power supply are you planning on using?
I’ve got a National Luna DC25 power pack that I feed my solar and my DC charger along with shore through to an 100ah lithium battery
For those of you who aren’t doing permanent mounts, what sort of ducting are you using?
I’m trying to pipe air from a heater in the bed / on the ground up to a RTT. I got some ducting intended for permanent installs and found it does not hold up to handling at all, it rips if you look at it sideways. Dryer vent would be a bit more durable but pretty awkward to work with.
I am toying with the idea of making a solid PVC contraption and just having a small section of flexible duct (from heater on ground → PVC going up to RTT level) but that’s a big clunky bit of stuff to carry around. I’d rather have flexible / collapsible ducting but I can’t find anything durable. Any clues?
This is the one I use. It’s like a dryer vent inside but it’s covered in pvc so you can handle it. Oh and it collapses back down pretty easily.
Ok so I decided to go with the aluminum box style found in this link to upgrade from the big plastic tub I currently have my heater in.
https://www.revereoverland.com/diesel
I do want to heat the entire truck box and camper and found I was able to no problem with the 5kw heater. The big question is do I cut a hole in the truck bed itself or cut a hole in one of the GFC alu doors and install a 3" blast gate to duct the heat in?
Did you do the heater linked above by whiteroom? There seem to be a million of those images under a bunch of different names! So you guys are putting the heater outside, and routing the hose in through the tent zipper? I have a 2020 Tundra and would like to heat into the bed, but don’t want to cut a hole in the bed…looking for options.
@Whiteroom that is my issue exactly. I don’t want to cut into the bed, but want heat in the bottom in case I am sleeping down there in bad weather…wish we had the tool cubby like the Taco’s do to cut out a duct hole…
Check out my setup…although I’m about to mod the box and make it permanent.
https://forum.gofastcampers.com/t/diesel-heaters-do-you-all-use/16705/9?u=dignon
Which diesel unit is that? Planar?
Yes the planar 2kw portable.
Nice rig. Are you liking the heater? Seems like it is a game changer!!!
