Sorry just seeing this…If you’re still up for doing this
…I can send to the next person when I’m done.
Info sent thanks!
The video shows this already, but this is how these line up with lock holes on my camper (which had them from the factory).
This is the lock that I use. Fit the drivers hole fine. Had to notch the lock a bit. If you could buy this lock with a 1-1 1/8 inch length it would be perfect.
That’s funny, I bought this one to see if it would fit as well. It’s in my garage and I need to return it because it didn’t fit the hole either. I think both locks are the same diameter, that one is a little heavier though.
I bought the same one and it didn’t fit on my V2 either. Also never returned it, heh.
You’re welcome. Do I get royalties? Swag? ![]()
Just did the same as a couple others here. Thinner hitch pin lock found on amazon. Drilled hole using a very tiny bit first. No jig needed. Just felt approximately where I knew hole should be, used probably a 1/16" bit and tapped the pilot hole. Then a larger bit that fit my lock pin.
https://www.amazon.com/dp/B00CSBR6UQ?psc=1&ref=ppx_yo2ov_dt_b_product_details
Now get that Lock Locker from UMF ( @Vice_Chief )
