I have both kinds of leaks. I also have a slightly sloped driveway and get a solid flow into the bed. It also happens while driving in the rain. I guess I need to put in tickets.
Another person here who has submitted a ticket (in my case the 2nd ticket for water intrusion) and I received the same recent comms from GFC. Iām encouraged with the response and rain testing, Iām also a little skeptical since right around a year ago we all heard this was sorted with the weatherization fixes.
So, thank you to GFC for being responsive and fingers crossed for the root cause to be identified and fixed.
Hey @Tyler-Kai i had another thought, have you Seam sealed/shoegoo to all 4 lower corners of the exterior portion of the tent yet? I did that almost immediately because I noticed about 1:4ā - 1/8ā gaps in almost all 4 corners. I never had any water in but this was done almost right after I got it and didnāt experience much water exposure yet. Just a thought. I saw that and noticed a potential problem.
I also noticed that the inside of my tent had the lower 4 corners sealed with a small bead of black sealant of some sort from the factory. Not sure if they started adding that or not at some point.
Just some more thoughts. I hope you can get this solved as a $5k tent should not leak.
I have not shoegooād anything on the tent at this point. I think that probably could help prevent water from finding its way past the fabric portion and into the sleeping area; however, I think there is a bigger issue in that the entire back portion of the tent is getting wet in the first place.
My guess from what Iāve tested on my own is that the rear, upper aluminum billet is a big culprit of my water intrusion. But Iām sure GFC will be able to get to the bottom of this with all their testing.
Got it. Good luck! It seems like you have a good grasp on a potential source. And yes I agree with you, the amount of work and resources GFC is putting in is promising. Hopefully a solution is reached soon.
Iād still encourage you to do it. Itās so versatile and light compared to the competition. The customer support is fantastic and they will stand by it from my experience. Iāve had my RTT for 8 months now and I love it. I sleep in it about 2-3 times a week for work and I wouldnāt want another setup l. Itās rapid deployment and takedown is very smooth. Thatās my two cents. :). Good luck making the decision.
Noticed this today. Some white marks from water getting though looks like. Wondering if itās some mildew? This is where the tent portion connects to the camper. Looks like thereās some gaps in the glue/black silicone they use.
I get that. I run a small businesses, too - one of which involves manufacturing - and Iām big on customer support as well. But the product needs to do what itās supposed to do, I think. And the #1 job of a tent, Iād say, is to keep water out.
I love that itās fast and light, and I freakinā love the price. My 2nd choice is an AluCabin mounted to a custom-built box on top of a flat bed (because the AluCabin wonāt fit my truck, and Iām not changing trucks). That option will run me probably $50k by the time Iām done and weigh several hundred pounds more.
On top of that, Iām in NC. I donāt relish the idea of a 2nd trip to Montana to have issues fixed. Iād rather spend that time doing what I want to do with my truck.
I guess what Iām saying is I LOVE the idea of the GFC, but I donāt love the idea of getting wet. Looks like these guys are working on it; I hope they get if fixed soon. Iāve got a big trip coming up in August and I intend to have my new setup - whichever one it is - in place by then.
is it white powder looking stuff? itās part of the glue. It usually happens when itās smeared(or in this case compressed) while still wet after installing. my previous job was putting that glue in the tube
Thatās exactly what it looks and feels like. I have not noticed it before so Iām pretty certain this is new. Can you share any more info? I take it thatās probably not a good thingā¦
Iām sure @blackhearse can give you more useful information, but I sealed my trailer build using an adhesive/sealant and have had similar looking areas show up. Even a year later new spots seem to show up and I am assuming it is just more uv/weather exposure over time. Everything is rock solid and it does not seem like an issue in the least.
I personally wouldnāt stress about it, but you could always submit a support ticket to keep a record of it in case something changes down the road.
it takes a while to show up(mine has it too) and does not affect the performance of the sealant. the boxes and tubes are labeled with ādo not tool or smearā because this happens. Next time you are in home improvement center check out the OSI Quad Max boxes. Basically you have 2 parts in the glue- resin and āfillerā. the white is the filler coming out because isnāt encapsulated by the resin anymore
Damn. I read this whole thread and pains me to know how many have this water intrusion issue. And how many more who are not on this forum that we do not know of.
Hopefully GFC has a solution and can fix this problem. I still have an open ticket for my delaminating front windows on my tent since August 2022.
Haha! youāre right about Sequim, but if you know that town, its not where the truck spends the majority of its time. Thats why there are dry enough times in the winter to air the baby out.
Well Hell. Thought I was a lucky one ⦠until today. Very small amount of rain over two days and the truck was parked slightly nose down. Turned the truck around to do some interior work and a friggin waterfall came inside from the immovable front panel on the driverās side. I say waterfall as thatās exactly what it was, maybe a pint worth of water came in at a near steady stream. Still dripping slightly but itās not enough to fall, just run into and down the forward tube support.
Doesnāt shake my view on GFC as a whole and Iāll do my own troubleshooting before asking for assistance ⦠but damn. This was A LOT of water. Assumption is the frame filled up based on that parking angle then disposed when facing the opposite way. The troublesome part for me is where the water was coming from. No where was it visible where it was āstoredā. Any thoughts?
