New install problems
Its all good. Yea. Didn’t look right to me .
They’re working on it. Should get the replacement panel in a few weeks. Hopefully it works
I second @GFC_Support to retorque your bolts after any off roading. I did about 20 miles of fast rough off road and my front mounting bolts were loose enough to let the camper shift into the cab. Had the tools but otherwise it would have made for a very slow return trip! This in no way GFCs fault as things come loose with that much vibration and I had not checked the fronts since install.
Did anyone ever get torque specs for the mounts?
I’ve done several hundred miles off-road and am yet to re-torque :sweat_smile:
Ive put on thousands of road miles and maybe 200 offroad, and mine are still nice and tight. But will start monitoring them more. Will also need a torque wrench :woozy_face:
What should they be torqued to?
From my knowledge there is no torque spec. Which I believe has been mentioned a few times.
That’s what I thought. I just got mine installed on 8/11 and it has the same gap.
No that didn’t fix anything
