May be a bit early to get this discussion started, but I am definitely interested to know if the GFC V2 will be compatible with the 4th gen tacoma!
They are for sure making one for the new Tacoma. I believe that I read the bed spec is completely different compared to the third gen.
I have a gladiator so it doesn’t affect me, but I really wish they could do something different with the rear hatch and the deep tailgates. I hate how the topper looks like it’s too short for the truck because the tailgate is so deep and the topper stops at the bed side instead of the exterior side. If that makes sense lol
as a follow-up, can anyone confirm if a v2 on a gen 3 tacoma will fit on gen 4? doesn’t sound like it, but wanted to confirm
Pretty sure @GFC has said the V2 from a Gen 3 will NOT be compatible because of that rear “fin” on the 4th gens. They can confirm though.
Just look at the side profile of a 3rd gen compared to a 4th gen. There is no way the gfc will be compatible lol
They have one listed for the Gen 4 Tacoma on their website. Not compatible with previous gen tacoma’s.
Anyone ever try a 2 / 3 gen Tacoma model on a 4 Gen? I have a lead on a 2 gen 5’ Tacoma Model.
There was a guy down in Mexico that moved one from a 3rd gen to a 4th gen. Because of that fin or whatever you wanna call it on the back, he had to cut and trim that back panel completely I think. There was a lot of cutting per his IG stories lol
Here is my 2 and 3 Gofast mounted on my Gen 4.
I put the 1.5" spacer tubing on the side rails; otherwise, I would need to remove the tailgate spoiler.
I know it looks a little crapy with the tube sticking out, but with no support under the front wall, I wanted to make sure the bar would spread the load as wide as possible. Also see here the spacer plate. It is 3m VHB tapped to the bed and the underside of the support tubing.
This system clamps to the bed rails without issues?
Yes, there is enough adjustment in the factory bracket to add the 1.5” (40mm) spacer tubing!
Hi, I am attempting something similar in a few weeks. Would you mind sending me some photos of the antenna clearance and how you resolved the gap that the spacers make on the tailgate?
I’m planning to use 1” trex boards to raise the entire camper up 1”. Hopefully that’s enough for the camper to clear the antenna.
