Anyone aware of a company making molle panels for the cab side window in the GFC V2 Pro?
Not that I’ve found. Underland Outdoor doesn’t have a pro model yet.
I’ve reached out to a couple companies with no luck.
I bought the underland V2 version and drilled holes in it. Works absolutely fine with weight on it.
I have the V2Pro on a 21’Ranger and ordered the Underland Molle Panel.
A few things you have to consider when purchasing from Underland…
The Part / Shop:
When I ordered for the V2 Pro, there was no label that said it wasn’t compatible with the V2 Pro…
It is also a bit thinner than expected. After 5-6 weeks of waiting, mine showed up bent, holes were for V2 not V2 pro. I emailed multiple times, , called their shop multiple times and have still (months later) haven’t heard anything back. I will never do business with them again. Their customer service gets a zero stars. If a competitor is looking on here, please make a panel for the GFC and take these guys out. -
I tried to sell it at a loss, but not a soul bit. So I decided to modify myself and take the risk of messing it up, which thankfully I didn’t.
The Install:
The holes for the V2 molle panel match in the middle but are incorrect for the left and right sides. You will need to drill holes yourself. (this was actually not as bad as I thought it would be). Also it doesn’t come with any mounting hardware.
If you have the V2 Pro with the LED bar that is installed on the white part, will need to be removed. The panel when mounted covers up that back row of LEDs and won’t sit flush to the metal bars.
Getting the double stick tape off and removing the LED bar took me an insane amount of time as it was mounted on with the strongest double stick tape I have ever encountered. After I was able to remove the LED bar, I mounted the Molle Panel, then re-mounted the LED bar a few inches back towards the back of the vehicle.
Agreed. I emailed them with no response. Then DM’d and commented on a post on IG, all with no response. Seem to have no interest in answering questions or helping their customers. I decided based on this not to buy a molle panel from them even if it is easily modified. If your order gets screwed up you are shit out of luck.
Wow, glad I posted this. Good info.
I can confirm the non existent customer service with Underland Offroad.
Zero response to a question I had about my molle panel order, which after about 2 months of silence, I eventually I decided I had to cancel.
….surprisingly they handled the cancellation in under 5 minutes…
Fortunately, my experience with all the other guys creating solutions for the GFC has been top notch!
I had emailed them directly and received a response same day. Ordered and received in a week. V2 XL. Product is very nice and well designed.
You’re using the v2 model or the v2 pro. I am about to do the same as I ordered one not realizing it wouldn’t fit. Did you simply drill where required? Any issues drilling or particular bit? Thanks!
Thank you - super helpful. In the exact same boat with a Tacoma.
I thought I had seen a post that Underland was looking for V2 Pros for test fitting an updated molle panel. For what it’s worth, it seems to be a secondary brand run under the same roof as another company called Colorado & Canyon Enthusiasts (CCE for short on many of the Colorado and Canyon forums). I’ve never had any problems with orders I’ve placed with them, but I’ve never had to reach out to whomever is responsible for responding to customer inquiries.
As simple as can be for the drilling. The top and bottom center holes matched up so I only had to drill a few others.
i’m sitting here in freecad laying out out as i type this. Actually logged into the forum to make a post to figure out what the different dimensions are to support more then just my camper on my 24 ranger…
