I don’t have one but I agree that the Alu-Cab ladder looks like a good contender for mounting to the GFC t-tracks. The mounting bracket included has bolt holes all along a single line so it should be easy to put on the GFC.
I would recommend the beefier 1/4-20 tnuts for mounting the bracket. However, it is likely that the backside of the bracket is flat and does not contain recesses for where the tnuts sit proud from the GFC extrusion. You can slip nylon washers around the tnuts to make up for that. Here’s an example:
https://www.lowes.com/pd/Hillman-6-Count-0-500-in-x-3-4-in-Nylon-Standard-SAE-Flat-Washer/4582511
I personally have the iKamper ladder, which doesn’t come with mounts so I made some using aluminum square tube, tnuts, and the nylon washers linked above.
