We’re picking up GFC this summer and camping our way back East. I’ll take come hardware along based on all the posts I’ve read (eye bolts, tie-down anchors, tent pull). Aside from an Allen wrench/hex key, what are a couple of other go-to tools? Furthermore, what specific Allen wrench key/s are needed? Thank you!
I can’t remember the exact allen key size but I would recommend a general purpose tool set similar to the one below. I bought this a few years ago to keep in my truck full time and its got pretty much everything you need including the allen keys.
https://www.amazon.com/Crescent-Professional-Tool-Storage-Case/dp/B08BJCQ663?th=1
For some peace of mind for you, I haven’t had to touch a single bolt on my GFC unless I was adding something.
But I just went and checked:
Allen Keys:
5/32"
4mm
3/16"
5/16"
Sockets:
1/2"
7/16"
5/16"
Torx:
T30
Other:
Flathead Screwdriver
Super, thanks!
I got one of these little leveling tools for free with some shelf I bought years back, and surprisingly I use it everytime I find a spot. I use the top of the closed tailgate as a reference surface.
I also chock a wheel religiously, even in a flat parking lot.
Make sure you’re getting high quality tools. I have drilled out many screws that were stripped by others using soft hex keys. I personally use Bondhus brand, pretty cost effective, Wiha is also good.
I second this. My Bondhus hex keys fit so well they hold the bolt on usually. Makes a BIG difference on the often loctited GFC bolts.
Thanks for this info. I’m picking up a used GFC this coming Memorial Day weekend. Very helpful. Not trying to steal this thread, but since you all have the technical knowledge, I should have between 6-8 friends helping me lift the GFC from seller’s truck to my truck. Is that enough? I know it’s only about 275#, but I anticipate it being a little awkward due to the size. Thank you.
I have done it with 2, but it was a bit rough, so 4 is great and 6 will be easy!
Whats a good hex bit socket set brand?
I have a set of Husky metric, standard and torx in my truck. I also keep a full set of harbor freight ones in case of another tool failure, or for when those who aren’t prepared need to “borrow” tools. Redundancy with tools (space dependent) is extremely helpful when on trail. I’ve had to replace coils/plugs, heater T and hoses in my old land cruiser and my off roading club had to replace an axle and knuckle on a LC that literally had a wheel fold in (imagine rolling an ankle inward). When you have every possible tool you’d need to fix a car on board, it makes it so much easier (and cheaper). Depending on the trip, I now even carry my 1/2" impact gun.
haha I also have a bunch of these little level cylinders that I think came free with some picture frames that I tossed in my glovebox and use when leveling out my truck. They rest perfectly on the t tracks of the gfc and once level toss it right back in the glove box.
I did this set and the holder is really nice too.
Came with Bondhaus brand which are USA made and great quality. I think really as long as you aren’t doing harbor freight, husky, or some other big box store brand you are set.
If you’re installing a used GFC on your truck, consider ordering new weatherstripping from GFC to place under the camper. I believe GFC typically installed the adhesive side down on the truck rails so good chance it can be damaged if trying to remove it. If it is a Tacoma also look at sealing the rails to the bed.
3M side toward the GFC on my Tacoma just was installed at HQ. Same with the truck before me (some white full size I forgot to look).
That sounds like an exciting trip! Along with the Allen wrench/hex key, I’d recommend bringing a multi-tool, a set of screwdrivers (both Phillips and flathead), and a small adjustable wrench. As for specific Allen wrench sizes, for GFC setups, typically 5/32” and 3/16” are used frequently. It’s always a good idea to have a complete set just in case. Also, consider packing some duct tape and zip ties for any unexpected fixes. Safe travels and happy camping!
I had not fractional allen keys of any quality… this was the best pricing I could find on a set of bondhus:
This is what I have and recommend. Bondhus is high quality and reasonably priced on Amazon. Careful you can break the balls off if you are using a cheater bar on them.
