Think this setup could work to connect multiple domestic go hubs to the domestic go faucet, I don’t mind the slower pour but I do dislike having to swap containers. Could I modify your setup to connect three domestic go containers to the single faucet?
You could probably make a multi container connector with a drip sprinkler manifold
Also, some additional info for those brave enough to buy parts off eBay or temu/aliexpress
From Dometic: “The coupler at the end of our hose is an “APC” series CPC valve. What’s used on almost all hydration bladders. The coupler is the same size for ¼” and 3/8” tubing and the port on the back of our faucet will fit ¼” tubing.”
