I agree. I think if you want max clearance and mtb at the same time that’s the way to go. I have considered this. My only problem with a bumper that is a full-time swing away is it will always be on my truck. I drive with my tailgate down sometimes and stuff hanging out of the back.
I just bought and received a Rigd UltraSwing. Haven’t used it on a trip yet, probably will in the Spring. Real solid piece of kit, there’s no wobble in the receiver connection.
although the swing arm isn’t rated to hold 6 bikes when swung out, it can hold 4.
Do you have a picture of the Rigd setup?
Very interested in this setup with spare and 1up once I get my gfc in a few months. I have Yakima swing away with older version of Yakima holdup on truck now, not a fan of how far the swing out sticks out off back of truck.
Thanks
Wait 1, I’ll take some pictures tomorrow and post.
I hope this helps. I didn’t get the wheel plate, I’ll just mount the bike rack and a custom bracket to hold some other gear.
Hey thanks, so just to confirm you have the ultra swing not the mega swing from Rigd?
I ask because I have a tundra so probably similar width as your truck and wondered if the Ultra cleared the tailgate. Also with a bike will it clear in full swing from hitting side of truck.
It appears yours will clear.
Post the full setup when your done, may have to copy you!
I cut & pasted this from my order:
“RIGd UltraSwing Hitch Carrier Mega-Fit”
UltraSwing is the name for the product, which has three versions: multi-fit, 4Runner, and mega-fit.
I decided on a 1up bike rack with Rakattach swing arm. I really like the 1up rack. Super strong, high quality, easy to use. I went with the single rack and got an add-on.
What do you all use to lock up your bikes when they’re on the rack?
Bought a handful of the wheel locks from the 1up website when I bought their track and swing away. Super quick and easy, plus everything is keyed the same.
I have the wheel locks from 1up. I use these if I am going to leave the bike for a short time. If it’s going to be all day I put the bike in the gfc and chain it to the frame.
I run the 1UP heavy duty double with a dual hitch extension so it clears the gate. I was going to go with the Rack Attach but I couldn’t justify the cost for a little more convenience. Once I remove my armor for its re-powder coat (I do every few years) I will put a hitch receiver directly on my gate for the 1UP rack.
Pic of your rack and bike?
When I go out Friday I will snap some picks, currently I only have the rack on the truck. I still need to order the 1UP license plate relocation.
Is that a swing out on swing out?
Insert a “Pimp my Ride” meme about putting a swingout on a swingout.
But yes it is. I didn’t want to add the extra stress on the swingout. Two jerry cans, a spare tire, hi-lift, and two bikes all on one pivot arm seemed to excessive, so I added the swingout bike carrier to alleviate some of the stress.
I should state the rack attach is the way to go but I have my money tied up in things at the moment. This works for now though. I set it at the bottom so the gate will clear but this rack is so easy to use if I need the clearance I will flip it and run it that way and remove should I need to get in the rear gate. Great thing about the GFC is I can normally use any of my panels to get in the bed.
Where did you get that dual hitch mount? Looks like I could run it as a riser for toting bikes off road. Am I correct?
