Bracket for OVS Awning?
Any lessons learned on mounting an OVS 270 awning to a GFC camper? I have seen this set up in person, just want to know what I’m getting myself into b4 I purchase the awning and mounting hardware. Thanks.
Got my OVS 270 XD (largest one) a week ago and installed by myself. I used the method someone else on here mentioned - attaching one bolt on one end, then using a fulcrum maneuver to raise the awning so I could attach another bolt at the other end. Got all bolts set up on four GFC Universal Awning Mounts (i’ve been collecting them for a couple years, so thought I’d rather go overboard).
It was only after everything was completely tightened down did I realize I hadn’t positioned it properly, so the rear arms wouldn’t open all the way - the whole awning needed to slide back about 3 inches. No amount of loosening, shaking, lifting, hammering, etc. could get the damn thing to budge, so I completely removed it and will try again this weekend. I did notice that one of the bolts had become wedged in the awning track and had to pop it loose with a screw driver and a hammer.
Everyone mentions getting shorter bolts and I cannot stress this enough. My awning came with 6 short and 8 long bolts. With four universal mounts at two bolts each, I was 2 short bolts shy, so I decided to just try and use the longer ones. The problem with them is that you cannot get a closed end of a racheting wrench onto the nuts on the longer bolts. The shorter bolts allow enough space to make it work. It took as long to attach 2 long bolts as it did to attach the 6 short ones.
Since my local hardware store didn’t have the correct ones, I ordered these online and will use them on my second attempt:
Needless to say, it is possible for one person to mount these, but an additional set of hands would have made it 100% easier. In addition to using the “fulcrum” method, I used a cargo strap, wrapped around the awning, over the top of my camper, and held in place on the opposite side by some jiggering of one of the GFC Machined 90 degree mounting brackets.
I should have taken some pictures, but I was so defeated by my improper placement and endless wrenching that it was the last thing on my mind. I’ll try and grab some this weekend and update this thread later.
