Here’s a tip I used to mount the wires wires in my GFC. I used a heat gun to heat up and form a bend in the flat base zip tie mounts. Works well and hopefully others will find it useful.
I just replaced mine with a ziptie?
I never know why people use those stick on holders, they never last…
Do you mean you just wrapped a zip tie around the space frame itself? If so, do you see any issues with making the seal less effective and letting in water, dust, etc.?
I just used zip ties around the space frame, back passenger side vertical post. 3 zip ties, foam on the door formed around them and there are no gaps or leaks
I used self-fusing silicon tape and the results are good so far. It holds up well and does little to deform the gaskets.
