I’ve been thinking about getting the turbo nap for my v1 but I added a 1 inch pad that is shorter in length and width than a twin size mattress and it’s still really hard to close. So I’m worried it will be a pain to close if it’s 3 inches at full dimension. Has anyone tried a turbo nap in a v1? I know gfc says it works but wanted to see if anyone has done it. Thanks
I decided to upgrade with the Turbonap and it does close fine. It takes a wee bit more pressure to lock down the camper latches, but not much. In my opinion the upgrade, is way more comfortable. I do not regret changing it.
Same reply as above. I havent slept on it yet, but am looking fwd to the soft fabric cover instead of original firm, slippery fabric. Closing the GFC always takes a minute longer than if it was a thoughtless process.
So are you guys closing the v1 with the turbonap AND bedding up there? I gave it one try with a doublewide Big Agnes sleeping bag in there and after a minute of fumbling said “screw it” and threw the sleeping back in the back seat of my truck as per usual. Should I have been more patient?
If u center the added bedding it will close but the camper will have an obvious bend to it when closed
