DC power station?
Let me start off by saying I have very little working knowledge of off-grid power solutions. I’m thinking about adding a power station to my build to power/charge lights and electronics as well as a future fridge and possibly an electric blanket or pad. All the power stations I’ve found are expensive and have limited capacity. While solar may be a future addition, I’m not planning to add that right now so I’m looking for something simple, economical, and with enough capacity that I don’t have to stress about running out of power for most trips. I’m also not looking to commit to a full-on dual battery set-up right now.
Enter this gem I found on the internet: 100Ah 12V PowerMax LiFePO4 Battery / 1280Wh Portable Power Station
Does anyone have any hands on experience with one of these?
Looks like it’s made from a Renogy battery and Texas instruments BMS. It’s a one-stop-shop for powering DC stuff with plenty of capacity at a great price. If I wanted to add AC equipment later I could add an inverter. Any smarter folks out there see any pit falls I don’t? I’d need to get some kind of LiFePo4 charger, and maybe even a warmer of some kind to make sure it works at colder temps, but it seems like it checks all my boxes.
Any and all feedback or suggestions of other solutions are much appreciated!
I use a 100ah heated battleborn battery in a National Luna DC25 power pack ( green top) and it works perfectly and does what you’re looking for
Thanks. That looks like a nice setup, but also about 5x the cost of this Dr. prepare setup which is why it almost sounds too good to be true.
I would recommend SOK Batteries. Heres one that has bluetooth and a heater circuit built in. High quality cells, BMS, construction, and is serviceable.
The “too good to be true” question occurs to me as well. I have a Goal Zero 1500 with a 200AH solar briefcase at a cabin, and a Jackery 1000 with 2X 100watt panels for a backup and portable solution (backup at the cabin and to use in the GFC while on the road). Solar panels are cheap, although needing to add a charge controller will add to the cost if/when you upgrade. For me a solar charging option and AC output were a must. The great thing about both my options is that they include both AC&DC output, overload protection and the controller all in a neat, easy to store and transport package. The Jackery is my ‘cheap solution’ and it is orders of magnitude more expensive than the option you are looking at (the Goal Zero double that). All I can say is both of the systems that I have have exceeded expectations…which is the key word here. When I am at my cabin (Utah…plenty of sunshine) I power a larger Dometic portable fridge, wife heats water in an electric pot for coffee and dishes and we run minimum lights with the Goal Zero. On sunny days we can use an instapot to cook dinner. After two days of clouds at the cabin I decided I needed a backup so I added the Jackery…although I only recharge the Goal Zero with solar (I can and do recharge the Jackery while driving). Anytime you start to heat stuff it really drains the battery. So expectations is the key word. My personal recommendation would be save money until the next Jackery 20% off sale (which seems to happen a couple times a year) and go that route. If that isn’t an option I’d recommend really nailing down your power requirements and determining how much charge you will generate (how much of your time is driving and how much stationary in camp?)…could be the system you listed will work for your needs.
Only negative comment I have on Jackery is that their solar panels are only water resistant while Goal Zero are waterproof…although there is no reason you couldn’t connect the Jackery to a waterproof panel.
Last comment. Cold temps certainly affect battery capacity and performance but, as I understand it, the real issue with cold temps and lithium batteries is not charging them while cold. I solve that by keeping the Goal Zero inside my cabin and recharging the Jackery in the cab of the truck while driving…because warmers consume part of the electricity I am trying so hard to store and use for other things. Again, a point in favor of easily transportable self contained systems like Goal Zero or Jackery because I don’t have to worry about something bouncing around and shorting the connection between the controller and a separate battery.
Good Luck!
Great breakdown. If cost were not a consideration, I’d definitely go all in on a large Jackery/Ecoflow/Bluetti/etc system and never have to worry about it ever again. That might just be the best option - save up and get a complete system that can do it all rather than piecemeal it as my needs evolve.
This forum is great to bounce ideas each other.
I agree. I had a hybrid F150 before my current Lightning, and while it was cool that the truck would turn on when it needed to recharge the Jackery… it also meant that in the middle of the night, it would turn on to restart the Jackery… which usually woke me up. If I had it to do over again, I would have got the biggest Jackery I could to run the refrigerator, heating blanket, and charge stuff and not run out at night.
I have a Lightning now, so will be interesting to see how that does with camping power consumption.
I don’t have any experience for this battery but it looks pretty compelling to me for the price.
I like the YouTuber Hobotech for boondocking tech reviews. He made a recent video review for this battery:
That video is what really made it sound like a viable solution to me.
That battery seems like a sweet deal in a really well thought out box. That being said: I doubt it will be a complete solution for you. I am just some dude on the internet so take my opinion for whatever that is worth, but here is what I would want to upgrade after looking at that battery.
Likely you will want a faster charger, both from solar and a charger at all that will plug into the wall.
Also, I would be nervous about bare terminals just kicking around in my truck bed so I would want to build a box around that battery.
Third: the power level monitor is almost certainly voltage only, which for a lithium battery is really mediocre. I did it for a while and it’s a recipe for killing your battery.
Last: while inverters are awesome, our campers are really tiny, so I have had a really hard time finding a place that I feel comfortable mounting something with unfused 2awg wires hanging off of it.
This is exactly the kind of info I’m looking for. Thanks for the insight.
I took the plunge and ordered the Dr. Prepare setup. As an aside, it pains me to type that ridiculous brand name. Fingers crossed it is decent quality. It will be my house battery which will mainly power my ARB fridge and diesel heater.
Looking forward to your review! It’s top of my list right now, but I’m still doing some research on alternatives before I pull the trigger.
I recommend the EcoFlow brand for batter/power supply/inverter. Very easy to read the panel, to set up and provides a variety of DC/AC and USB charging options. It’s been very reliable for me and I charge it on house AC before leaving on a trip, then have 300 w of solar panels (3) on top of GoFast while on the go, and whole system works better than expected. I have this model of EcoFlow:
Good luck!
How did this battery measure up to your expectations? I’m gearing up for a multi-week road trip this summer and have yet to find anything better for the price. Would love to hear your take on it.
Too early to give much of a review as I have only used it on one trip so far. But it is working as advertised to date. I have a Renogy DC to DC 40amp charger that I have connected to it.
I do not yet have my fridge wired to it so the only things it was powering was my diesel heater and some phone/iPad charging.
I installed a couple of different set-ups - started with a dual battery system under the hood using an AGM battery and REDARC BCDC1225D. I used an Off Grid engineering kit. I thought i could save some cash with the setup and do it all myself. It works and the Odyssey Battery I have has lasted a long while. However it’s heavy and the battery will not last more than a day or two without some sun. I never bought an inverter for it since I already spent a ton of money on the setup.
This year I added a Buetti Power station BLUETTI EB70S - it works well and lasts at least twice as long as the AGM batter and has a built in inverter. The only downside to this unit is that the DC is limited to 10 amps and the inverter is limited to 800 watts. It can’t power a few things I have but it works great with the lights and charging my phone and accessories. I also bought a Dr Prepare 100ah Battery that I’m using as an extra power source to charge the EB70S
If I had to do it all over again, I would not go with a dual battery system. It’s a lot of work, not as inexpensive as you would think and doesn’t last as long as I wold like. the next power station wold be something similar to the BLUETTI AC200MAX with the advance of a 30 amp DC output and 2200 watt inverter (you can find ones with higher output but they tend to get heavy).
hope that helps.
Wondered what brand of solar panels you are using on top of the go fast for this set up and whether you need to have anything between the solar panel and the power station?
Here’s my bed area setup:
I run a LiTimes 100A 12v LiFEPO4 inside the All Top battery box. All Top one has 12v ciggy ports, 2x fused 50A Anderson connectors, voltage readout, and 2 external terminals included for $80. LiTimes LiFEPO4 was around $260 for their end of year sale.
To charge it, I opted for a Renogy MPPT-equipped DC-DC charger. I run a 6 AWG power and ground cable to the starting battery with a trigger wire to my LP6 backlight that’s connected to my Switch-Pro 9100 set to turn on when ignition is on (so I don’t need to run another wire into fuse box for ign on/off) That way when the engine is running the battery gets charged.
I then run power and ground from the LiFEPO4 to a Blue Sea Grounded Fuse Block for my camper lights and to run the diesel heater. I also added a bus bar and a switch system to control the accessories. (Aka battery->power and ground to fuse block ->power and ground to the switch system → switch system controls power to the Bus Bar → accessory power side runs from the bus bar).
So far I can run camper lights for both upstaris and downstairs for 6+ hours and diesel heater for over 12 hours and with 1v drop.
I run fridge via my Ecoflow systems in the cab. I went that route because my Ecoflow not only powers the fridge when the truck is off (I have a hot wired cable to the battery for the fridge when vehicle is running) but also Starlink as well. I have combined 3000wh of power on the Ecoflow side and ~1000wh of power on the bed side.
I thought about doing dual battery for the bed side but realized I could get away with it and achieve the same result with my current setup while only put down under $500. The only downside is the bed side battery cannot be used to jump the starting battery, which is fine. I have a jumper pack for that purpose.
edit: the best thing about it Renogy DC-DC charger has an optional bluetooth dongle so I can monitor it while driving.
Following up on my Dr. Prepare 100ah battery. Now that I’ve had it for about a year & several trips I can say it has been trouble free. It powers my ARB fridge and diesel heater, plus the occasional phone/iPad charging. So I’m not putting it in any extreme situations but all in all I am happy with the purchase.
