Good morning all! I am curious about possible demand for a diesel heater bracket. If you have any sort of 2KW heater with the standard hose, you can install horse trailer vents (found easily on Amazon) to each side wall of your GFC & add this bracket to create a really nice way to funnel your warm air into the truck bed.
I just installed everything and tested over the weekend, and it worked really well. I thought I would see if anyone else would be interested in ordering this custom bracket before committing the time and energy to create them in bulk. Cheers!
The benefits of the horse trailer vents go beyond your diesel heater. You can use them to create a cross-breeze to allow the warm air from your powered fridge to escape the truck bed (making your fridge more efficient), also to create positive pressure when cruising dirt roads (to prevent dirt from building up in the bed) and to keep animals safe when traveling with all panels closed (as it will provide airflow to mitigate heat buildup in the bed).
You could also zip this bracket into your tent wall up top. It is not optimized for this, given the strange shape, however it would be more than secure if zipped into place - no hoses slipping out at 3am when it’s cooooooold and you are sleeeeeepy.
I am not offering the horse trailer vents, you’d have to buy those yourself
I would create some affiliate links to the product for future reference, as that would help generate a little bit of a revenue stream to me. I could pass that savings to you via the brackets!
