I know that GFC carefully builds these to the specs of each truck. Not sure how similar the bed is between a long bed taco and a nissan frontier and if a camper made for one would fit the other?
Thanks
Thanks
Its not just the bed dimensions, they also match the rear cab angle and cab height off the bed. With that said a V1 might be more universal then the V2 since with the V2 (specifically from the Tacoma perspective) the campers are now specific to a generation. The short answer would be is to get really detailed measurements from someone with a Tacoma GFC (I would even compare generations) and see how that matches with your truck. As far as reaching out to GFC customer service they only recommend running a camper built for your specific make and model.
Makes sense, thank you!
