Has anyone out there mounted anything to the bottom of the front fixed tent floor panel? If so, I’d be interested in how you did it and if the mounting hardware affected the cushion above. I’m thinking that would be a great place to mount a rack for my 2-piece and 5-piece fly rod cases to stay off the cabaña floor. I’m just at the idea stage of this project. I have the V1, btw…
Ok. So I’m thinking about this again…
Has anyone mounted to the underside of the bed panel closest to the cab? I’d be interested in how you accomplished that. Also, is there any reason that I can’t drill through that panel? Not sure what’s inside or what a drill bit might encounter. Are those panels constructed of wood or something else?
This time I’m thinking about adding additional general storage rather than a dedicated flyrod case mount.
I believe the floor is 1” thick plascore. Similar to the roof but twice as thick so a lot stronger. You can unzip the removable square mattress pads to get a look at the material.
I’ve seen a few posts on the forum where people have drilled through it to pass wires so I don’t think you would have a problem.
Edit: forgot you have a V1. The front panel might be different on that one I’m not sure.
Fwiw VHB works great for this application. I have a narwheel mount right there. I have driven several thousand miles with a wheel mounted on it and it hasn’t moved.
I thought about the 3M tape, but I will be using this space for different storage depending upon the type of trip I’m loading for. I’ll post my completed project when its done. Decided to go with these for attaching to the panel.
Our Products : Tie Down Straps : Winch Straps : Lodi Metals, Inc.
Going to use straps to to hold my storage container so the container is removable when not needed. Then I can use the straps for other things. Gives me some flexibility without an extensive addition to the camper space.
Oh! Those look awesome. I have climbing bolt hangers on pretty much every frame mounting point GFC builds into these things. I really don’t know why they don’t just come that way? It’s like $20 worth of hardware and makes your rig WAY more configurable.
I used a cargo net in that section instead of mounting anything to the tent platform floor. If you intend to store varying things up there it doesn’t get any more flexible than a net IMO.
My fly rod, paper towels, and a kite live up there year round. I can open the cargo net to the eyelets in the middle of the frame when additional stuff needs to be stashed up there.
My hardware envelope showed up empty. Didn’t know that strap hardware was a hot commodity. I’ll be dealing with that into the new year, I’m sure. I have an idea for securing my wife-friendly bedding with flexibility for times that I just go with solo bedding.
