SOLD SOLD SOLD
Selling a EcoFlow Delta 1300
Details
The EcoFlow DELTA 1300 solar generator is one of the best selling portable generators on the market. With it’s 1300W hours lithium-ion battery, you can charge up to 13 devices simultaneously. The DELTA 1300 can power a wide range of important devices including full size refrigerators, CPAP machines, phones, laptops, lights and much more. The DELTA arrives charged and ready for use. Need more power? You can connect up to 3 fully-charged DELTA’s in series to get continuous power from 1260Wh to 2520Wh to 3780Wh.
Whether you are at home or off the grid, The DELTA is one of the most versatile portable power stations around and represents the new standard of battery-powered generators. Compatible with a wide range of devices, you can stay powered for hours whenever and wherever.
RECHARGE 0%–80% WITHIN 1 HOU R
EcoFlow patent X-Stream Technology empowers EcoFlow DELTA to recharge at 10 times the speed of most portable power stations in the market.
6x 1800W AC OUTLETS & 1260Wh CAPACITY
The large inverter load enables EcoFlow DELTA to power most home appliances and heavy-duty DIY tools under 1800W (3300W Surge, Pure Sine Wave ) with 1260Wh capacity.
FASTEST RECHARGE BY SOLAR AND CAR
EcoFlow DELTA can be fully recharged by solar panels in about 4 hours, and fully charged through a 12/24V car port < 10 hours.
POWER 13 DEVICES SIMULTANEOUSLY
EcoFlow DELTA fits with every port you’ll ever need to power any devices anywhere, so you will always feel right at home.
CHAINABLE FOR CAPACITY
Users can connect multiple fully-charged DELTA’S ( Up to 3 units) in series using the AC charging cable to get continuous power from 1260Wh to 2520Wh to 3780Wh.
Downloads
Specifications
Capacity:
1260Wh
Charging Speeds:
1.6 Hours to fully charged using AC Wall Outlet
Unit Width:
10.6"
Unit Height:
8.3"strong text
Unit Length:
15.7"
Item is in great condition
Selling because I went to a more permanent solar system in my rig
Located in Riverside CA.
Price: $575
Including a 100 W All Powers portable folding solar panel. I have all the original manuals for the EcoFlow
