Has the windows out the back, and brake lights, attached levels to help with parking. Upgraded mattress pad and custom red flannel sheets from Overland Softgoods (only used them about 6 times)
Really clean tent, all zippers work, no holes or stains.
Side panels are in perfect shape and the locks all work great!
Hi, it is available, it will work on a 2nd gen taco, you would want to look into getting the following replacement seals to help with the rear panel. I have chatted with the GFC customer service about it and they said it won’t have quite as good of a seal as it does on the 3rd gen taco but honestly you can fix that with some extra seal you can add after the fact if it bothers you.
