Any know if the GFC power pack has enough punch to run a chinese diesel heater?
Box says 60w, but I cannot seem to get mine to keep running.
Thoughts?
Thoughts?
What are you trying to use as the output?
If you are trying to use the usb c (the one they advertise the 60w on) that is a 5v nominal circuit.
It depends on the specific heater you are using, but in general what I have seen the 12v/24v needs a minimum of 10A-15A for the startup phase/ to ensure you don’t get voltage errors
for instance, Vevor, one of the more common ones shows the need for 15A in their users manual:
Thanks… yeah it isn’t enough juice. Even the vehicle battery isn’t enough. But the vehicle running is. Now I gotta sort a bigger battery to run it…
Running it off the 12v not the usb-c.
Thanks!
Even my Goal Zero 500x didn’t have enough to run one. The 1500x can but only through the Anderson style plug. One of the reasons I ditched using a diesel heater.
100aH house battery system minimum. You can get cheapo stuff off amazon that works ok. I’ve built about dozen systems. Let me know if you need help.
Check out my build thread for my latest power updgrade to a portable solution (DIY).
