I posted a bit ago about a diesel heater that I ordered from Amazon. I can’t get it to heat! The instruction manual doesn’t cover the LCD screen controls that I have. Wondering if anybody has experience with this one and could point me in the direction of a set up guide or video?
This is probably it; need to prime more than likely. On mine, it works something like this. Try pressing the two buttons at the same time, OK and UP or Gear and UP at the same time. (Try down if up doesn’t work). It should show a ‘H’, then cycle it with the up/down till it reads ’on’. You’ll here the pump solenoid cycle for a while and it should turn off after it’s complete. Return to home screen of the 24 hour clock then try starting after this. Repeat priming if it errors out and it should work.
-Ron
