Weigh your truck at a “Cat Scales” and you will know how much weight you have on each axle. That will allow you to make an informed decision. They have an app for your phone, it’s pretty easy.
On my Tacoma I had 1200lb constant springs to counteract the weight from the Camper, wooden drawer system, and a steel swing out and tire. It was a bit oversprung so I would wait to make any changes to your suspension before dialing your whole suspension in.
Gotcha. What did you do to dial your’s in? I guess having it weighed would be the thing to do
Weigh it stock and then weigh it loaded down on something like a Cat Scale as @Semi mentioned. That way you are sure of the weight before you upgrade your springs.
