I try to park my truck so I can open the most amount of windows as possible. Worst case is I only get to keep one open if sideways rain/snow starts blowing in the other windows.
I used my GFC as a basecamp for a lot of mountaineering objectives so no matter the temps the GFC always feels much warmer than camping on glaciers partway up mountains. When it gets to sub zero temps in the GFC I just make sure to bring my heavy duty, warm mountain sleeping gear. Layering has always been easier for me than worrying about heaters.
@WrinkledPants and his team of experts are currently working on a solution. Patience is key, as they want to make sure they get it right, can support it, and cover any issues that may arise.
I finally got my Maxx fan installed, just waiting on the hardware to fasten it down. I did a few things differently compared to the others. I also plan on modifying it by adding a reverse switch. I really like how slim this model is even if It does lack on some features.
External wiring modification. I used a waterproof cable glad and water tight conduit to run power along my solar tray. This “hides” all the wiring on the inside. I also ran the power to my rear facing Baja Designs S2’s that sit up top to provide a “street light” over my camping area.
I also added an “upstairs” USB and 12v junction box. I have a Sirocco II Elite brushless fan that I modified to use Ram suction mounts and a cigarette plug so you can use it anywhere. This sticks to the ceiling and gimbals to blow air wherever. I have a plug upstairs and downstairs it’s super quiet and way more efficient then the Maxx fan. Afterthought, but this fan alone probably would be sufficient.
Correct. It’s a PVC junction box with the BlueSea in the Lid. It doubles as the pass through for all the wiring to the upstairs. I actually cut the top layer of the panel and inset it as much as possible.
The main downside is you cannot slide second panel for storage. I was thinking to notch it out so it sits flush but I just put it on top of the front cushion and that works fine.
(Photos before I notched the panel so the box sat lower. I also cut the pipe sockets off.)
It’s Model 0004401M same as used by others in this thread. From what I could find it was the most slim model available. It’s pretty simple having only 4 speeds, no remote or auto open. But you modify it for reverse flow very easy with a 3 way switch.
As for the trim piece it’s excessively long (6” or so) but it’s designed to be cut down as required. The actual fan body requires no modification but I trimmed the side flanges off about 3/4” so it would match the inside trim but that is only cosmetic.
Did a test, night one no bottle, 2 old guys single digit temps. Walls and everything else so much condensation. Front corner windows open… night 2 diagonal cross venting with a bottle in the upper corner of the back door single digit temps. Minimal condensation. I think this is a winner
Hello Folks! I’ve been following this conversation intently as I’ll be getting my V2 installed in a couple weeks. While I’m sure the powered fans solve the condensation problems, I’m wondering about a lower tech solution that splits the difference between the powered fan and the zipper-mod with plastic bottle approach.
I found this livestock trailer vent and was wondering if there would be enough room to accommodate the interior portion of the vent mechanism? From the schematics it looks like it has about 3” depth on the interior portion of the vent. Is there room for that with the tent closed?
For the inside trim I found it gets hung up in the corners. I just notched those out about 1/4”. There are unused inset threaded holes in the corners that prevented the trim from sitting flush.
I understand this perspective, and that may be ultimately where I end up. That said, I prefer to keep it simple. If I can solve the problem without adding more wires, power consumption, or noise that is a better solution for me.
I cut two of those same vents into the side panels of my camper. I put a post up with pictures where you can see how far they come in. The roof is thicker so you might have the bottoms stick out a little less but they protrude in a lot. I’d think you’d have to take out your mattresses or at least suffer having them push into the foam a lot. They are great vents tho and seal up nicely.
Thanks @CEM, I appreciate your input. I tracked down the thread with your photos - vents do look nice installed in the side panels. I may give this a try in the roof but I’ll wait to actually take delivery of my V2 to get a better idea of how much space there is under the roof and can better evaluate how bad the condensation issue is in the cold.
I’m excited to finally get this thing on the truck but need the resist the urge to solve problems I don’t even have yet…
I think it is safe to say that most everyone on this forum built and re-built their camper several times during the final days, weeks and months leading up to that glorious day that the camper became ONE with the truck. Most of us are probably not known for our patience. So… what are ya gonna do???
