How to fix roof? Replace?
i used some vhb on the underside of the white roof, to mount some velcro. I suspended a blanket to the ceiling to absorb condensation and help block the light. Anyway, I put a couple velcro pieces in the wrong spot. To remove them, I used the spray gel goo gone version (not the solvent), Amazon.com: Goo Gone Adhesive Remover Spray Gel, Removes Chewing Gum, Grease, Tar, Stickers, Labels, Tape Residue, Oil, Blood, Lipstick, Mascara, 2 Pack & Sticker Lifter : Health & Household. Spray a little bit on the leading edge of the strip, then go do something else for 5 minutes.
after a few minutes, the gel goo gone should have loosened enough so you lift the end of the vhb tape a little. Just enough so you can now start spraying the goo gone right where the vhb bonds to the roof when you pry it up a little. A thin piece of wood may help too, like a square tongue depressor. Once you get a tiny bit of the vhb up, you can start spraying more aggressively, right where the VHB meets the roof. Keep paper towels on hand to wipe up the excess as you spray
Keep the go gone liquid away from the tape GFC put on around the perimeter to keep rain/snow out. Thoroughly rinse the roof off with water from a garden hose when done. Good luck! Do it in a shady spot too, be patient, let the goo gone do the loosening work. if you get too physical, you’ll damage the roof. You’re only lifting a half inch to an inch per spray, and you have to wait 10-20 seconds per spray once it starts coming free. Takes time
Well, I’ve had the unfortunate experience of finding the same fate as @Jake_Bull_08 when removing my panels.
The outer layer had ripped in multiple places but my main concern was the ā€˜burning’ or ā€˜charring’ that the damaged panel had caused to the roof.
Not sure if this was because of a cheap Lensun panel I used or if damaged panels do this.
I have reached out to GFC about roof replacement and they also quoted me $300 but I will opt out of driving to Montana HQ and hope Basil’s Garage will do the work.
I am going to install my replacement Sunflare Xplor 180w panel anyways because of the several camping trips I have planned this month.
I’ll just have to remove it and reinstall it after the roof is replaced.
Sort of makes a good argument against installing flexible panels directly to the roof, but I know plenty of people on here have done so with no issues
Yeah I don’t think flexible panels are the full blame. Maybe don’t step on them so you don’t damage the cells and create an arc of electricity. The heat was a non-issue for the 4+ years I’ve had the panels. I would opine that ā€˜cheap’ panels are just that, cheap for a reason. My replacement Sunflare has advertised several times over the amount of damage a panel can take. I feel confident in my decision even though I am taking a 120w loss compared to my old setup. Time will tell though and I’m eager to see how well these ā€˜bypass diodes’ work.
For what it’s worth, I had the ā€œexpensiveā€ Sunpower panels and they burned. There’s some combo issue here where water gets trapped underneath, a section of the panel shorts (maybe shading related), and then the heat from the short is really efficiently conducted into the roof, damaging it as the panel blows.
After two panel failures and a roof overheat, I built a rack to float my remaining flexible panels off the roof. No issues after that, but now they weigh and cost more than hard panels. ĀÆ|_(惄)_/ĀÆ
Curious how well the Xplor holds up.
You are probably already considering this, but I’d suggest for your temporary mounting of the panel, mount with as little tape as you think will hold it, just to make it easier to remove.
The xplor panel came with tape, 2ā€ wide might I add. And after confirming roof replacement with Basil’s Garage, they won’t touch the panel for that reason. They don’t want the liability of damaging during removal. Fml.
GFC did send me an invoice for the roof panel. $406.08 shipped. Basil’s Garage charges $185/hr for labor and quoted 2-3 hours.
Thinking I may upgrade to the V2 Pro tent and call it a day, albeit an expensive one.
They pulled my roof panel when my tent was replaced under warranty. If you replace the tent maybe they can install the new panel with no extra labor cost? This was also at Basil’s.
This was talked about when I called and spoke to the Basil of Basil’s Garage. Essentially, one job (roof) takes x-amount of hours, and the other (tent) takes y-amount of hours. They will just bill me from when the timer starts to when they finish the job. Mind you it was a ball parked estimate on number of hours each job would be separately but yet the conversation did end with the thought of doing the tent upgrade at the same time due to its cost effectiveness for me/the customer.
