Ideas for portable fan
How do I get one? I need this for summer camping!
How can I get on the list ?
Add me to the list please.
I could see where two, one each side, would be optimal. I’m in for two when you’re ready to ship.
Appreciate the interest! I just put up a site to keep orders organized. I am building these in small batches and have parts on hand for the first ~10 units.
If you are interested, you can grab one there now. I will build and ship in the order they come in and keep the thread updated as things move along.
https://lakelanddesignworks.squarespace.com
The two fans idea is great! It would be easy enough to switch the fan direction and have one pull and one push the air out. Great solution for those hot summer months. Down the line I could also see using smaller fans for a similar application, I just haven’t found any that are the dust and water proof yet.
Any questions or suggestions let me know!
Woo Hoo!! Order No. 00001!!
Right there with you YetiX.
Order #2 Confirmed
If it’s a great product, I’ll be getting another.
That’s a super rad design.
And the vacuum bagging of the wind fairing - so cool - apropos of the screen name
Thank you for your order! I’m making progress, I had some quality issues with the magnets i originally used and need to order some more. Those come in tomorrow. Then its time to ship!
Thank you! Your order is also in the same place as YetiX, waiting on magnets. Are you think about having an Intake (Pull Air In) and Exhaust (Push Air Out) still? For sure doable with the current model (Intake) but the PWM Cable gets little long. Maybe there’s a concept for a second offering.
Hi CFG,
Yeah, I want to get the first, see what I’m dealing with, and foresee getting a second. My idea is that when it could be warm, but rainy and the windows need to be mostly closed, I have one on the left sucking in, and then the other reversed mounted pulling the moist air out. I’m all for longer power cables, gives me more options for placement of both the fan and the power pack mounting.
That’s really cool! I’ve actually been working on a similar design/idea but ment to be kept in place in the upper triangular window so it can be ran in the rain. I’ll post some pics in a while once I get one or two more parts together.
Here’s the project i’ve been working on!
Its limited to a 100mm fan due to the opening i’m targeting! I’ve also toyed with side blowing fans in the front windows which aside from potentially blowing in rain water and their noise can really really move air!
Quick update on this thread since several people suggested an exhaust fan to pair with the intake.
I finished development on that version and just updated the site with both options.
The idea is a simple matched intake/exhaust setup that mounts through the tent mesh, stays out of the way, and helps move heat out more effectively in the summer.
Appreciate all the feedback on the original post, a lot of this came directly from suggestions here.
Updated page is here:
Happy to answer any questions.
I got to use mine a couple of weekends ago. It worked great and the circulating air was really nice to have
I’m glad you got to use it and were happy with it!
I meant to share the picture. I got a USB extension cable and plugged it into my Jackery and it worked great. Didn’t draw much power either.
