Just bought a used v2. Are the latches on a v2 supposed to have a rubber stopper? Mine have a place where they would screw in but it is missing. Seems to close fine but concerned about wear.
It’s always been metal to metal
As far as I’m aware and if I understand correctly, the latches do not have a rubber stopper on the backside. Some of the older V2s had longer arms with a bolt whereas the newer ones just have a shorter arm like the rear latches. Hope that helps!
Do you mind reaching out to our CX team or posting a photo of the latch and what you think might be missing? Just want to make sure all is well given that you bought the camper used.
That looks like the rear door and that’s exactly how mine is. Totally normal; should be flush with the interior aluminum blocks on both sides
