Latches
anyone have any luck finding latches other than the GFC ones that will fit on the doors.
This discussion might help…
I am on my third set (1 set was free) and the ones for back gate just die so quickly it is sad. My back has 1/8" + clearance now from all the flexing. I am looking to make something that will spring load against the bracket that holds it closed.
I tried closed cell foam as a spring and it kept it closed while it lasted, though it wasn’t very long.
If anyone has some spare time and money…they make electronic triggered latches. So you could (in theory) unlock and lock your GFC panel with you car fob which would be VERY nice. They have a manual override as well and look to be the same model as the existing patches.
i wouldnt be worried about cutting the hole, i would be more worried if the arm on the latch lines up with the backing plate the arms touches.
