Leaking Corner from V2 Platform Camper
I have a approximately 2 years old GoFast Camper V2 on a 3rd Gen Tacoma short bed and just recently
I noticed a leaking issue from one of the corners from the tent portion. I’ve noted that it seems to be slightly on both sides but one is far worse than the other to the point that it leaks into my truck bed below. Wondering if anyone has experienced similar issues? See the photos below to see what I am talking about:
You can see the tent fabric is wet. I noticed it also go into the camper and got the mattress partly wet when it was raining one time.
In this one there is a small amount of water that has gotten through but not sure where it would be coming from.
It results in running down the side of the camper in the inside until it results like this on a wood platform I built below:
Looking at everything, it seems like my camper seals properly, and is structurally intact at all the seams, but hard to tell. I imagine even a mm of space somewhere would be enough in a heavy rainstorm to allow water to leak through. Here’s all the seams I checked:
On final note I also wanted to show that the camper is closing properly AEB this photo:
The water intrusion fix that GFC came out with a while back included adding the black sticky tape to those corners. It’s the same tape used around the perimeter of the roof. There were also color-matched tent fabric “hats” that covered up the black tape on the corners, but just for looks, no other purpose.
Hey @Doc007 I’m having this same issue. Did you ever figure out where the water was coming from or what you did to fix it?
Also getting a lot of water coming through here, anyone find a fix?
Ghost town :ghost:
Have you tried the water ingress fix at you nearest GFC instal shop?
I’m in Canada and in a remote location so I’m not sure if any retailers near me. Is there a document on the work, I could do it myself?
