Lighting switch failure?
I have a fairly new v2 Pro XL, installed 1/9/2025. I connected the lighting to a 100Ah 12v LiFePO battery and have been running that way until I get something more permanent wired up and installed. Yesterday the lights died, indicator LED on the 4 button switch panel is not lit. I thought maybe it was the battery BMS but swapped to another fully charged battery and no joy. I’m going to troubleshoot, but wondered if anyone out there has seen these switches fail?
No issue with my switch, have easily over 1000 presses on it
Did you hardwire it to the battery or use the included cigarette lighter plug?
If it is the latter it may be possible the fuse in the connector popped
I have it hard wired. I checked and there is voltage up to the input connector for the switch, so it isn’t power, it isn’t wiring, and connections are good. Seems like it must be the switch. Thanks,
Gotcha, thanks for clarifying, last bit of troubleshooting I’d recommend, does it work if you bypass the switch connection, or the Y splitter?
If so I’d recommend reaching out to GFC support.
GFC sent me a new switch and I installed it. It works fine, problem solved. Cheers.
