SOLD!
I’ve got a V2 on my '21 Ford Ranger Crew Cab. The camper is in mint condition, only slept in 3 times. I did a full build out and am passing along most of the accessories I’ve added.
Here’s the low down:
GFC V2 for '19 and up Ford Ranger
Front and rear windows (awesome for parallel parking, negotiating tight trails, etc)
Sandstone tent fabric with doors on both sides
3 beef bars
AND I have a brand new bulb seal on hand to install on your truck
AND a bunch of extra small hardware for accessory mounting, etc
I’ve also added -
Kinsman hardware 270 degree awning
Renogy 175 watt solar panel on custom mount that sits just below beef bars so that you maintain unrestricted use of bars when needed
Rear window molle panel
Renogy DC to DC charger and MPPT solar controller
VRNCLR frame packs (2)
Interior led lighting with dimming and red lighting
USB ports
Add all that up and I’ve got about $13k into this part of the build. I’ll take $9k for the whole setup.
I’ve had some inquiries about separating out parts, here’s what I will/won’t separate and pricing:
GFC V2, 3 beef bars, solar panel and wiring, interior lighting, VRNCLR frame packs: $7000
Kinsman Hardware 270 deg awning w/GFC V2 mounts: $1900
Molle Panel, Renogy DC to DC charger / solar controller, USB ports: $200
SOLD: Rigd Ultraswing Multi-Fit with Sidehack, folding table with cutting board, trail pouch, locking pin: $1200
In case anyone is interested, I also have a Rigd Ultraswing with all the options, a custom bed plate, fridge slide and 8020 decking built around using Radius outfitters boxes for an ultra-light organization up for sale as well. DM me if you want to dig into all that stuff.
Located in Bellingham, WA. The Ranger version of the GFC is pretty light, should be easy enough to transfer to your truck.
