Loose Side T Tracks
About to put an awning on and noticed that if I push and pull on the awning brackets the side T-Track is moving. The bolts are tight, what’s going on here? Its a Gen2 Camper 366? .
This is pretty much normal to see as mine also did it when I owned it #4xxx
Mine does the same thing. It makes me nervous that I could do damage to the camper by having things mounted up there. The tracks seem more like flashing than a standard aluminum extrusion.
You are correct. The track is NOT apart of the main extrusion but a standalone piece that is pressed/hammered into place and secured with a couple bolts along the track.
Well that makes me less nervous about doing damage to the camper. Thanks for the pic
So what holds it on? Just the two bolts? Is there a lip on top for some support?
There is a bit of a lip on the bottom but basically a tight fit and some bolts that hold it on from what I could tell.
So the beef bars are almost necessary to keep any weight directed straight down, and not pulling away. Just 2 bolts and that piece comes off?
Does the top t track work the same way? Just came back and noticed that’s not where the beef bars attach.
