Move pre-installed light strip
I want to move the pre-installed v2 pro light strip closest to the cab.
I’ve installed a molle panel and want to move the strip proud of the panel. Does anyone have experience detaching and re-attaching this light strip?
No experience reattaching but it is just 3m vhb tape so worst case you pull it off, scrape the tape and apply new tape. I installed mine after buying the lighting kit and put the lights where i wanted. Hope it helps at all!
Thank you. I realized that I can always take the molle panel down later on to move the strip. For now I’ve left it in place until I see how much important light blockage there is.
How did you find the panel and whether it blocked too much light? Im about to install my panel but was looking at moving the light a few inches forward.
I found no issue at all. Admittedly, I am not a heavy user. You may want to ask for a second opinion.
