Is overland soft good the only fitted sheet maker out there? I would love some sheets that aren’t flannel or fleece.
I am basically a furnace when I sleep and in the summer nights I would be boiling up, so I would love a fabric that isn’t quite as warm
Where are you located?
I’m the same way and have yet to find their regular, non-fleece, sheets too warm while camping in Colorado.
Add in a little higher overnight temps and more humidity, probably a different story.
With that, we’ve had a great experience with both the sheets and 1” foam topper from Overland Softgoods (@WrinkledPants).
I’m mostly in the north east, from New Jersey. So heat is a pretty big factor.
And personally, I sleep really hot, I don’t start using a blanket at night unless its under 50’ above that I just have a sheet, under 50 I do a light blanket and under 30 I’ll use a sleeping bag.
So need something that won’t cause me to boil when it’s 70 and humid in the mid summer
there are custom size sheet makers on both google and amazon
https://hest.com/ if you get their mattress and then fitted sheets…pillows are very comfortable.
