Post Your Pudding Here (2026)
Night 10, this one make it all worth it. Outside of Grants Pass, OR. Next picture was the morning.
:joy: this made me chuckle. Hope you get less bug bites on the next one!
The next two nights were blissfully mosquito free :smiley:
Nights 15 and 16 in the Flat Tops.
Day 1
day 2 retro fitted V2
day 3
Is the gfc mounted to an aluminum box on top of the bed rails? Curious as to why? More height? Did GFC extend the rear door to cover the gap for you?
Same question. It looks like 2x4’s that have been painted.
Maybe needed the height to accommodate the roof reack?
Back at the farm this weekend. Blackberries are unfortunately not yet ripe. Good news is I didn’t miss them.
Night 5 afternoon arrival yesterday…framing underway on the cabin.
I saw a thread where someone built spacers to fit a 2nd/3rd gen camper onto a 4th gen. The cab height is taller.
Funny you should ask.. I actually bought this GFC which was originally created for a Chevy Colorado 5ft bed. After doing some research it was very close in dimensions, angles, taper.. everything was less than .5" and a few degrees of the 4th generation Tacoma. I worked with a metal fabrication shop to create a welded heavy duty aluminum “U Frame” -to clear the roof rack and securely attach the camper to the Tacoma frame rails (this entailed purchasing the Tacoma t-slot hardware- otherwise everything is the same). It is the same aluminum spec used for Rossmonster overland rigs and will stand up to anything.
It’s extremely secure and adds a little bit of head room in the lower topper area enough to sit up comfortably. It also clears the roof rack with adequate room for the bed flex as well.
But to answer your question the back window door closes perfectly along with the tailgate, I typically run a Tailgate pad for my bikes so the little bit of clearance works pretty well for my setup. I may try to add a small piece of aluminum eventually once I get into some winter camping out here in Colorado and Montana. Cheers
Picked up camper a couple days ago. First night sleeping in it. Snake River between Jackson and Alpine.
Night 6. Hot and dry when we went on a drive.
Night 11, dispersed camping just outside Madras, OR. This trip was for going to the PNW Overlanding Expo. We went there on Saturday, won a Dometic CX2 45L from Dometic so, was well worth it. :money_mouth_face:
Night 12, Lost Lake Campground, OR
The Linville Falls campground has First Come First Serve but is offline until next year. Great area!
I’m pretty sure I camped next to you in Blackwoods for a night or two. One row over.
Nights 20-24 in Blackwoods campground, ME. We were in the same spot for the duration, so the other pics are of the area. That was the bridge to Canada!
