It seems the rear panel on my Topper has shifted. There’s good clearance on the driver side (to the lower frame cap), but the passenger side has been rubbing and the clearance is to small.
The frame probably settled and things shifted a little bit. Seems like a pretty normal thing to happen to a metal assembly like a GFC. Maybe follow steps for removing and replacing your rear panel to shift it back in the center?
This happened to me at one point after many miles of dirt. I loosened the arms in the corner, loosened the brackets, used a ratchet to pull the frame in, then retightened everything.
Not sure if pulling the bottom together would help my situation. The rear panel is contacting the bottom, right frame cap (when looking at the back of the truck/topper).
Have the same issue since day one on my topper. I was told that it was likely due to out of spec top braces and they sent me new ones. Haven’t installed them yet, don’t care enough about it anymore honestly. It’s annoying to look at for sure and I can stick my finger though the gap on the opposite side that’s making contact. I’ll get around to it some day. Tried the ratchet strap method and it didn’t work. Also had the Belgrade shop adjust and remount it and they couldn’t even solve it.
Upper left and right just inside the rear hatch have a short diagonal aluminum flat stock to provide racking resistance. I would loosen the fasteners on both sides and using a ratchet strap or come-along pull the tight side to the loose side and see if that helps. Attach the puller high on the right side and low on the left to rack it back into position. Then re-tighten the fasteners. Could be a manufacturing error, loose fasteners, or some trauma flexed the camper to the right.
