I need to remove one of the camper attachments from the bed rail so that I can install a rago accessory mount inside the track.
Is it literally just unscrewing 2 bolts and then re-bolting? Pretty easy? I have this vision of unbolting and then being unable to get it back on…
yup just unbolt and go, then rebolt…
everything work out as planned? Just tighten as much as you can and call it good when putting them back on? I’ve got the same issue to deal with, just want to remove each of the back ones and slide some t-nuts on.
yes, not a problem at all
awesome, thanks (i’m typing this from my parents place in Sparks, about to drive south to Death Valley for a trip)
