Does anyone have guidance on removing my V 2.0 camper top. I am having a hard time with the brackets. I think I have figured out the tools needed are SAE, not metric. I have look through the forum without much results. Any help would be appreciated.
I have not found any metric hardware on my V2 GFC. Based on memory the bolts holding the camper down on my Tacoma are 3/8"-16 which use a 9/16" wrench. I use a socket for the bottom and a closed end wrench for the top. Note I have the old-style steel brackets, not the newer aluminum brackets.
Beware of tightening too much, after 4 years the sealing foam on the bed rails is splitting towards the front and camper has started leaking a bit. Of course this could just be age. Will be having it lifted and resealed in the next few months.
Hey Thanks!! Got it figured out. 5/16 Allen bolt and plain old 1/2 inch on bracket. Had to loosen the 4 screws with small Allen wrench in the bracket to get the 5/16 to turn. I guess every truck setup is different due to vehicle configuration. Appreciate the guidance. M
