I was just looking at DC to DC’s with built in MPPT. That’s the route I should’ve gone, but I cheaped out on the controller and just got the PCM 30A. But it’s all speculation until I get some sun on that panel.
I have the 30amp PWM wanderer controller, 50ah Renogy LiFePO4 battery, and 175watt renogy panel. It seems to pull at least 35-40 watts even on cloudy winter days.
That’s a very similar setup, except have 100W panel and 100aH battery. I’m really going to have to dig into this tomorrow. It’s looking like I might have a bum panel. Would you think scraping ice off it would damage it?
I have had flexible panels still work well following a lot of physical abuse, but have settled on using rigid panels partly for their longevity.
I hope to have a similar set-up done here in a few days, will report back. 100w flex + 100ah lithium as well
Google shade affects on solar panels. Each panel is configured differently but a lot of the less expensive panels don’t have many bypass diodes to handle partial shading. If shade was hitting your panel there is a chance that it was essentially preventing any energy from going to the panel. I have 4x 100W panels, 2x 170 Ah lithium batteries, MPPT solar, and DC to DC. I knew about the problems caused by shading going into my design (MS in Computer Engineering) so I connected my system with two parallel circuits of two panels each to increase my odds of getting a charge when one of the lines was shaded.
Thank you so much for the insight. I discovered this this morning. When I was driving around at one point the panel was putting out 14w in the sun. Turned a corner and, whammo, it went away. So that’s totally what’s happening. I’ll be looking into a dc to dc system in the near future.
Where do you have all the room for those panels? I’m thinking of adding one more panel. The funny thing is I need the power mostly in the winter when the sun is low. In the summer don’t need as much power.
You can see my solar setup here. Four panels basically take up the entire roof with enough room to spare on one side for skis.
@PNW Now you really got me thinking. It seems from my reading that adding DC to DC capabilities is not as easy as plug and play. Because I have a Wonderer controller, I realize I should’ve spent the extra bucks and just got the proper DC to DC MPPT controller.
Where I’m still scratching my head is, if you build your own system. Do you need a way to switch between Solar, and Truck charge? Or is it ok to run both systems ( I know the DC to DC system will only turn on when 12V is keyed on)
What I’m thinking of adding to my setup is a 20A DC to DC charger from Renogy, using a 50A Terminal fuse, 50A breaker to feed the unit, then a 40A ANL fuse to the battery system.
The battery performed as expected yesterday at the ski hill with the kids running the heater for 5 hours (diesel). Today will be the test to see if the 100W panel can bring the battery back from 12.3 to full charge. If it doesn’t then I definitely need to look at a secondary charging option.
It should be totally fine to run both systems, no need to switch between truck and solar charge they will do it on their own. I run both systems at the same time with no issues as neither one of the systems will overcharge my battery so if one is putting out more juice than the other the lower one just reads it as a charged battery and doesn’t push any power to the battery.
as for fuses I run a 100A for my direct charge system with the alternator and a 20A breaker to protect my MPPT. after that it all goes to the fuse box of doom to run everything else. Not sure that you would need to fuse after your charge controllers to protect that battery but I am not running lithium so it may need it.
As a user of said charger, I’d recommend go with bigger if your alternator can handle it. I use my second battery every single day but just driving a total of about an hour a day won’t charge the battery to full. when it’s warmer and the fridge is running I need to plug in a charger when I get home. I’m not running any solar yet and IIRC the manual said not to mix the 2 systems?
I have a 30a DC-DC and get up to 30a from my solar setup. So I see 60 amp combined charging the battery sometimes. I went with all Victron system, highly recommended.
There is no issue to run them simultaneously.
I have a set of 4 circuit breakers next to one another in my house electrical box. They control each sub-system as follows: SPod, consumers (everything besides Spod: fridge, lights, usb, etc), turn on solar charger, connect solar lines to solar charger. I also have a circuit breaker right next to my truck’s battery to that allows me to open the hood and enable power transfer from truck battery/alternator to DC to DC charger. As for fuses, I have quite a bit. To prevent any catastrophe you want a fuse or CB as close to the source as possible just in case a wire is cut, melts, or becomes lose and makes a short.
For fusing i have a 200 amp fuse at my battery positive terminal, a fuse on each parallel circuit of my solar panels, fuse tied to my 3 kW inverter, fuse for Spod, and a blue sea fuse box for each of the power consumer lines. I’ve had zero issues with the only fuse ever serving its protection purpose being one of the fuses to my LED light strips blowing because of too much power draw. I simply bumped it from 2 amp to 5 amp.
You should be able to run both solar and DC to DC at once. I’ve tested multiple inputs at once (solar, shoreline 120 V through inverter, and DC to DC at once. But in a real world application I’ve never had to run more than one at once. On a sunny day the DC to DC is typically the slowest charging system I have.
i had two 175w renogy flexible panels, neither would pull enough watts to register a charge on my battery so i returned em for a refund. renogy support is decent but they’ll make you measure the voltage and pay for return shipping unless your or their team can prove damange. in my case, they failed to evaluate in a timely manner after returning to their warehouse, so refunded me.
i realized i don’t need solar when i have a 500w charger. everytime i drive, even if its for 15 minutes, i put enough energy in my batteries that i can constantly stay in the 50-80% charge range to maximize battery life.
Just one. It’s big. Solaria 400w
I stiffened up the frame with some aluminum cross braces and made some panel supports so hopefully it holds up. It’s kinda overkill but it has the additional benefit of keeping the upstairs shaded and cool. I set it between two beef bars so they are still usable if needed.
Being a commercial panel it was a really good deal compared to buying multiple small panels.
That’s sick!!! I had to go the flush mount route because I intend on mounting my canoe to the rack in the summer. I just picked up 25’ for #4 for my Renogy 40A Dc to DC charger. So that’s the next project. It’s tough because I want to just have it working, but I also want the install to look good.
I have a solid feeling that I’ll be ripping everything out and redoing the whole set up with 1020 extrusion for the platform.
Victron LiFePO4 battery too? My ideal setup uses the following:
Xantrex inverter (2000W)
Renogy DCC30S DC-DC charger/solar controller
Victron BMS
Victron BP65
Victron LiFePO4 house battery, 200Ah
Victron battery monitor with shunt
Blue Sea house battery isolator switch
Blue Sea SafetyHub 150
Blue Sea 9001e switch (for isolating solar and/or starter battery)
DC circuits for fridge, LED house lights, exterior camp lights (not driving), and 12V/USB outlets. AC circuits for fridge (2nd power supply) and duplex outlet. ARB twin air compressor connects directly to the starter battery. Power needed for running an induction cooktop (1500W) and working remote.
