Looking for some guidance on how to mount a 50" Rigid E-Series Pro light bar. I saw another post with a similar question but no answers.
With the wind deflector on the v2, mounting options seem limited. Maybe it’s a bracket that attached from the side rails? Any advice would be appreciated. Thank you!
The front of the V2’s have a track to mount T-Nuts, so I’d use GFC’s 90 degree bracket and match them up to the L brackets that come with the Rigid Lightbar.
Also, if the end-to-end measurement of the bar is too long for the track, there are 3rd parties that make light bar cradles. Either way, I’d use GFC’s 90 degree bracket.
Thank you for the product links. I’d like to be able to mount it independently from the top hinge so that when I open the tent the lightbar doesn’t move. Most likely will need something that attaches off the side of the RTT. I will report back when I have found a solution.
Edit:
My hope is to get something like this. I guess they are fabricated by https://stellarbuilt.com
Oh really?! I never really looked closely. If that’s the case then yes, the 90degree brackets are perfect. I can’t find any examples online. If anyone is here on the forum and could post your lightbar + 90* bracket that would be amazing!
