I have a Bulletproof Diesel third brake light NMO mount. Due to the hang over the cab I will need a 90 degree female to 90 degree male. Or some combination of NMO to UHF without being hit by the tent.
Anyone have a solution?
Was looking for a similar cable. Will keep an eye on this thread for a solution.
Put the antenna on the tent?
I plan to and have bought the mount for it. I’m trying to connect my existing NMO mount that is part of the third brake light. I don’t want to have to figure out how and where to run another cable from my head unit out to the GFC.
Update: I’ve contacted a custom cable mfg and they don’t have a female NMO adapter. I’ve asked them to piece together a right angle UHF PL259 to 3’ RG-58 cable to NMO mount to fit an Opek or Tram NMO to SO-239 adapter like this one. >> NMO Adapter
I could probably just use an existing PL259 to NMO mount but I worry about the spacing and the tent hitting the bent cable. I should get my v1 next week so I don’t know exactly how much space I’m working with.
I could make one but, if they can spec out and build one better than I can for a few bucks more, I’ll take it.
This is basically what I am working with and the cable I am looking for. I bet you are looking for something similar if not identical.
FYI my current NMO is also on my 3rd brake light (Meso Customs baja designs w/NMO)
Yep, exactly.
I’m surprised there’s not something already. Outdoorsy trucks with ham radios and then add a cab over camper.
I’ll post back if they come up with something or I just piece something together. Would like as few connections as possible.
I reached out to Arc Antenna, which they don’t custom make cables which would work for us.
I reached out to Ham Radio Outlet who seemed promising but they told me they don’t have the right angle connector, which I think is necessary.
Awaiting a response from one more place and I don’t remember the name of the site/company.
https://www.dxengineering.com/parts/dmn-c213snmo
Getting closer to the right cable. Now to find a custom length. Would just need to find the right angle adapter end.
@ParWgn
Good news. I recently was contacted by Air802. They are able to make the custom cable.
That’s awesome. I’ll verify my measurement and call them. I might need 3’.
Thank you very much!!!
I’m supposed to pick up my GFC next Monday.
What is the projected height of the adapter and PL-259 right angle? How much room do you have between your 3rd brake light NMO mount and the underside of the GFC?
I do not have my GFC installed. My date is 3/20.
If you’re looking to relocate your rooftop antenna for better reception, try moving it to the highest possible spot on your roof, ideally with a clear line of sight to the broadcast towers. Even a few feet of height can make a big difference. Using a signal meter during relocation can help find the sweet spot without too much guesswork.
If the towers are in different directions, consider a multi-directional antenna or even a rotator to easily adjust the direction when needed. And, of course, make sure the antenna is properly grounded to avoid any issues with weather interference. For more detailed guidance, check out Sitebid for tips on relocation and optimizing your setup.
Great topic! Relocating rooftop antennas can be a tricky process, especially when balancing signal quality with structural considerations. It’s important to ensure that the new location maintains or improves reception, while also addressing any zoning or regulatory issues. Have any of you had experience with antenna relocation, or have tips for minimizing disruption during the process? I’m particularly interested in how others have handled permitting and installation logistics.
