I’ve gotten several PMs about the extendable pole and lighting….
They are the Ironman4x4 area lights
I have several 90 degree brackets mounted at strategic points and I’ll just screw in the pole where I need them as there is a threaded hole at the bottom of the pole…. 1/4-20 if I recall correctly
Thanks for sharing this. Will the GFC 90 degree bracket work for this? Or did you use a different bracket that works better? Can you kindly share some close up pictures of your bracket and setup?
Hi, the scene light install is great. What hardware did you use to mount it up? I have a couple 10/32 t nuts b/c they are flush but thinking the mounting bolt should be a 1/4. (as far as the bolt goes, did you cut it to length? or find one of the preferred length)
@ReedPowell The rigid lights are mounted to the Ttrack without any tnuts. Drilled a hole, ran the bolts through the track with a washer and nut on the other side. As for the Bajas, I used tnuts with just matching hardware and a washer.
