Installed: Protec Front Wheel Well Splash Guards
Installed: Freedom Coast x GFC MODmount Pro Pack Accessory Rail System
Need to attach the Bedding catch to the side rails also trying to figure out something else to help support the bedding catch in the middle.
Installed: Updated UMF Camera Mount
Use More Force @Vice_Chief Camera Mount (WDR Camera Only)
Camera Mount
Fits the new Wolfbox G900 Pro Camera and G930 WDR Camera
Left is the new UMF Mount.
I like the larger overhang and the finish looks real good!
What’s the……bedding holder for lack of a better word you’re using to hold your gear up? The black piece.with elastic bands.
seeing how much stuff you can hold with your bed catch now i’m convinced I installed mine wrong LOL
fitting a -25F sleeping bag took most of the space on mine and mine’s supposed to be bigger!
It’s saggy haha which I made a post about for ideas on fixing it!
Vrnclr Bedding Catch
i mean, in this case i think being saggy is what i need. mine’s tight AF lol
How lol… Maybe I installed mine wrong…
that’s why i said i probably did it wrong LOL
@shadesbro Stunning build! I am very impressed with it all
I appreciate the kind words!!
Installed: Freedom Coast Anchor Mounts For Bedding Catch
Still need to figure out my solution for the saggy center of the catch. (Maybe when temps are warmer).
Spitballing here. What if you ran a fiberglass tent pole inside the channel where the hanging rope goes (on both sides)? The rope would still hang the catch, but the tent pole would stiffen it up.
Another possibility would be tying the middle of the catch up to the t-nut rail that’s directly above it on the front, and then to the molle panel/ freeedom coast rail on the back. It would kind of “split” the catch, which isn’t ideal, but it would pull the middle up out of the way.
I did the grommet with the carabiner in the middle like someone else here did. And it works great.
And attached to what?
Here’s what I think they mean and what I did to keep the middle from sagging. Hooked a small carabiner onto the catch and to a mounted anchor on the t track. But where that t rack lines up on your truck is going to depend on your bed length, it wont be in the same spot for everyone. I have a 6ft bed and so it lines up perfectly with the width of a typical catch but on shorter beds I’ve seen it closer to the cab and not as functional for this purpose.
Doesn’t work on the short beds it’s towards the cab. Appreciate it though.
Oh yeah, I’ve got a long bed as well. Sorry man.
