Shasta — 2003 Tacoma TRD Build
Hey all! I recently picked up my GFC and have been hard at work turning it into a little home on wheels. I’ve been meaning to start a build thread to track the work so here goes nothing.
Background
I converted and lived out of a RAM ProMaster cargo van full-time for a couple years but had somewhat grown out of it. If you’re curious you can see that build here. While unintended, I pushed that vehicle to its off-roading limit so it was time for something new. After selling my van, I purchased a 2003 Toyota Tacoma TRD and ordered a GFC V2 Pro which provides a great base for a more capable adventure vehicle.
Goals
I no longer live in a vehicle full-time but still plan to use this rig for weeks to months at a time to explore remote areas of North America. My goal is to be able to comfortable support two people fully off-grid for up to a week or one person up to two weeks at a time. I’m also a remote worker so I’ll need a beefy enough power setup to allow me to work while on the road.
Planning
I happened to run into @DirtTrailsWanted earlier this year in Baja so was able to get an up close look at their build (huge shout out to them!). Their setup is pretty dialed in and I love their layout so I plan to take their Tundra build and use that as heavy inspiration for this Tacoma build.
Build Updates
Build Start — 8/26/25
While I didn’t have my GFC installed at this point, I wanted to start this build ASAP as I’d like to have it completed by the end of December so that I can make it down to Baja for the winter season. I began by installing a tailgate lock as well as a backup camera.
Flooring — 9/9/25
Using two large pieces of 3/4" 4"x8" birch plywood, I cut what would become the floor of the camper.
Cabinets — 9/19/25
I planned out all the cabinet dimensions by measuring the truck bed about a thousand times and creating templates in Illustrator. Once I was happy with my plans I cut out the pieces I’d need to size. Even without the GFC, I was able to roughly frame out the different components.
GFC Installed — 10/2/25
Stellar Built Off-Road in Sacramento did a great job with the install so huge shout out to them.
Solar — 10/6/25
With the GFC installed I took a break from the interior and focused on installing a 425W solar panel I picked up in Sacramento the same day I picked up the GFC. I first drilled two holes into the camper for wire pass through and then followed this post to create a DIY roof rack that would hold the panel and attach to the GFC.
Cabinets — 10/8/25
With most of the cabinets pre-cut, I was able to install the right side cabinets relatively quickly. To ensure a tight fit, I cut the lids at the end so that I had more exact measurements. I also added a few coats of wipe on polyurethane to help protect the wood.
Starlink — 10/20/25
I wanted Starlink to be permanently mounted to my roof so that it could be used in motion. I had intended to mount the dish to the roof rack but after mounting the solar panel, I was afraid the dish would partially shade the panel. So instead, I found some L brackets on Amazon that I was able to attach to the GFC and then mount the dish onto. It’s not my favorite setup but it’s good enough for now.
Electrical — 11/2/25
While pre-build power stations are a nice drop in solution, I want a lot of power and customizability so I decided to build my own system. I’m not going to go into too much detail but I installed an all 12V system with a 230AH battery bank. This should be more than enough power to run the fridge, starlink, computer, phone and any other devices I might need.
Cabinets Cont. — 11/14/25
I followed the same process I followed on the right to complete the cabinets on the left hand side.
That’s all for now but I’ll continue to post updates as they come. Thanks for reading!
So stoked see that you’re here! You absolutely crushed it with this build! Looking forward to seeing in person sometime!
Wow, you’re off to a good start!
I’m back with another lengthy update!
Awning — 11/23
I went back and forth on installing an awning but with my partner heavily in favor of some extra shade I decided to add an OVS 270 degree awning. I managed to get my hands on a set of GFC universal brackets which made the install process relatively painless.
Suspension — 11/24
Given that this is an old truck and one that wasn’t really designed to hold a lot of extra constant weight, my existing suspension was struggling. My base leaf springs were flat if not starting to invert and driving on windy and bumpy roads was a bit scary. I decided to bite the bullet and invested in some more heavy duty suspension:
  • Alcan Leaf Springs w/ 2" lift and 1000lbs extra payload capacity
  • OME Shocks and Structs
  • JBA Upper Control Arms
  • OEM Lower Ball Joint (common failure point and a good idea to replace sooner than later)
After the upgrade it felt like I was driving a completely different vehicle. It took turns smoothly and glided over the road. Well worth the upgrade.
Dividers — 12/1
In my old van I had a lot of space so didn’t really need to be organized. With the truck it’s more confined so I needed to be more conscientious of space. @DirtTrailsWanted had a great method of creating dividers from corrugated plastic sheets so I adopted a similar method of organization.
Mollie Mounting — 12/6
I knew I wanted to mount my backpacking gear and a shovel to the mollie panel which left some space above the fridge for additional items. Due to how close the fridge is to the panel, opening the lid limited what I could mount in that center area which was a bit of an oversight on my part. To still make use of that space I added a few pouches that hold common items such as toiletries, charging wires, etc.
MaxTrax Mount — 12/8
I was initially planning to mount MaxTrax to the side of the truck but really didn’t want to drill additional holes into the side of the camper. I ended up reaching out to @Wild_Mitten (huge shout out!) and getting a set of brackets that allowed me to mount the boards to the roof of the camper. Unfortunately the only space I could easily fit the boards was on the back (not recommended) so I’ll likely do some testing and revisit this setup again in the near future.
Faucet Install — 12/12
For water I added two 11L Dometic water containers and a Dometic GO Hydration Water Faucet.
Test Run — 12/13
With the build usable we took a quick weekend trip up the coast of California to test out the setup. There were a few minor issues with lids being a little difficult to open and forgetting a few essential cooking items but otherwise I would call the trip a success!
Not sure how I missed the initial build post, but this thing is turning out awesome. Congrats on the V2 pro.
I also stole the divider idea from @DirtTrailsWanted I have boxes which I remove from my truck and I made the dividers for them. This is my “kitchen” bin:
Love it! Honestly this is one of my favorite solutions, good camp organization is a game changer.
Looks great! It’s a super nice how easy it is to reconfigure as well if/when you add or remove gear from the setup.
Great job documenting everything, it helps so many others over time! Keep the lengthy updates coming, we love em!
