Starlink Mini mount and power
Hey y’all! Before heading down to Baja this winter, we made some changes to our Starlink setup. We switched over from the previous Gen 2 Starlink to the mini, and I wanted to drop some info on how we are powering it, and also how we mounted it and what we considered for our use case.
Starting with powering:
  1. Starlink mini - Pretty critical to this whole setup. We decided to switch from the previous second-gen primarily for space and the ability to run Starlink while driving.
  2. Alex Tech Wire loom. We took the supplied 50’ Cable and wrapped it in this wire loom; it’s something we do to all of our cables to protect them.
  3. Stargear Starlink Mini 12volt Adapter: We chose to use this to power the Starlink over using the supplied 120V wall adapter in order to reduce power consumption. This is directly hardwired into our power system.
Mounting Starlink:
  1. Starlink Mini. Pretty obvious part of this whole setup.
  2. Starlink Mini Ram Ball Mount
  3. Ram 1.5” Medium Arm
  4. Starlink Cable Extension - We are running this so that we don’t have to remove the mount (Item 2) from the dish to access where the cable plugs into the dish. Making it much easier to unplug the dish and to put it away if we are worried about it getting stolen while we are away from the truck.
  5. Alex Tech Loom protected Starlink cable. Again, we did this to protect the cable since it’s running along the roof of the camper.
  6. 1/4 - 20 Hardware & T Nuts - Stainless - This hardware allows us to bolt # 7 to the extrusions.
  7. Ram 1.5” Ball This is mounted to the extrusions using the hardware listed above. Whenever we want to remove the Starlink, this, the cable, and a small cable anchor are all that are left in place.
After 3 months of running this nonstop 24/7 on our truck during our travels to and from Baja, I can fully say that the Starlink setup has surpassed expectations. It has allowed us to have a consistent, reliable, and FAST signal while driving. Once at camp, we no longer have any process of setting up or taking down the Starlink since it’s just been in place the whole time. Whenever we do take it down, it now takes up so much less space than the previous one did.
Below are some screenshots of a speed test that I just conducted while at camp, as well as showing how the alignment is off, which doesn’t seem to affect the speed much. Overal the speed has been more than fast enough to allow us both to stream video calls, upload massive photo files, and listen to music all at the same time, it’s truly impressed us!
A note on positioning and alignment.
Because we rely so heavily on having solar power to support all of our electrical needs for full-time life and work on the road, we always point the truck south to catch the sun all day long. Starlink typically wants the dish aligned to point north, until you are very far north, then they want it pointed south again. We have had no problems at all with keeping the truck pointed south, except in the very southern end of the Baja Peninsula. It seemed like, at that point, we were starting to get spotty coverage. At those times i would point the dishes face directly flat; however, keeping its orientation south and that solved any spotty coverage. We will continue to play with this as we travel this summer, but i suspect in the continental US the direction of the dish will make little or no difference, even facing 180º in the wrong direction.
Some additional photos of how the mount looks on the truck.
I still need to address the cable run a little better. We were running short on time, and I had run out of my normal ziptie cable anchors.
Some things that we considered with this. We really still would like a much lower-profile mounting option than this. However, our solar panels and the headliner in the camper have prevented us from either mounting the dish inside under the roof material or on any portion of the roof on the exterior.
We have a friend who is making some great 3D printed mounts, and as badly as I wanted to run one of his, all of his options interfered with our solar panel placement. I think these are great options if you don’t already have things on your roof.
Anywho thats how we did. Let me know if you have any questions!
Keegan is a great dude, I have one of his Starlink Mini mount on my GFC.
Question, what is at the other end of the 12 volt cable? i.e. what is it plugged in to and how? I’d love to run mine on 12v rather than through the 110 outlet
He’s good people for sure!
At some I need to a whole electrical schematic of our truck but in short we are powering everything in the back off of a goal zero 1500x.
That battery has a 12v 30amp outlet on it with an Anderson connection. We have that connection wired to a 6 breaker blue sea 12v panel that we are using as the distribution panel. One of those 6 breakers we have wired to the Stargear 12v adapter.
We have a write up here about our solar setup, some of that detail is out lined there but not in great detail.
Got it. I have a Jackery 1500 that I use. Could I wire something to plug into my Jackery’s 12v outlet rather than plugging it in? In other words, could I add a “cigarette lighter” plug coming off the Stargear adapter?
Is there enough space between the two boxes on your cab rack to squeeze some 8020 extrusion in a way that would let you mount slightly above those boxes? Combine with you ram mount components you could have it lay flat during driving, then angle appropriately once parked.
Possibly but that area of the truck is rather hard to access. As it, it’s been pretty set it and forget. Aside from a handful of times in the southern tip of Baja we haven’t adjusted it all from the position you see it in on these photo, even with the top popped and the starlink being out of angle it’s been working great.
I’m not sure what the jackery specs are but here are some additional power options.
This is a cigarette port style adapter, reading it’s specs online it requires a port that is capable of delivering 144w.
Additionally you could run this cablefrom a usbc port. However the usbc port needs to be able to deliver at least 100w.
I haven’t used either of these options so I cant speak to how well they work.
The Jackery should have the 100w USB-C port on it. Mine does.
I used the roof rack mount from Starlink and mounted straight to my beef rack. It sits at an angle when tent is down and when up the angle is also not too bad so that I still get good speed up or down. No playing with it or having to install or uninstall it. I ran it for 3 days and in some pretty mountainous areas, some serious 4x4 crawling and dirt track traveling (only had to cut 4 fallen trees), only issue I had was when camping and had too dense tree cover, moved back 10 feet and it worked fine again. Super happy with it. However, I would also like to run it off my truck battery rather than my Jackery 110V (got the starlink 2 hours before I was leaving for my trek so it was whatever got it to work at the time). I’d like to get the hood mount solar panel to help keep the truck battery topped up and help power the Mini.
Has anyone had any issues with someone deciding to snag their mini when mounted like this? I just got a suction mount so I can slap it on the cab of the truck when I park and run it in the truck to my battery. I’d like to have it run while driving too though, but was always afraid of just having it mounted outside full time.
We haven’t noticed anyone trying anything with ours.
I’d like to think it’s safe from being messed with, even if someone did snag it, it would be useless to them without the passwords. So i feel like physically it has no value to someone else.
But with that being said, if we are leaving the truck unattended for a while I do pull ours down and put it away.
I take mine down when I’m going to be away from the truck for any significant time. Mine mounts on the top of the roof so it’s pretty high up. Someone would have to close my tent to be able to steal it.
That’s a good point. It really doesn’t have a ton of value to someone else. Man, now I’m re thinking my set up haha! Thanks for the insight and write up as always!
Thanks @YetiX
i mount mine on the cab roof and just run a USB-C cable to the battery in the camper. It is on 24/7/365, and allows my iPad to grab signal for Gaia GPS whenever (I am having issues downloading offline maps for Gaia, for some reason it’s not downloading at all and Gaia support is useless).
It sits in the middle of the cab roof, close to the GFC overhang. No one will see it unless they are taller than 7ft, or if they look at it from above.
Same.
Also when traveling with other vehicles, if they are in front of me they can often pick up the signal. Makes communicating things like screenshots/map areas easier when cel service is nil.
And, an 11 inch ipad dedicated to navigating real-time data instead of downloaded maps (they eat up memory space quickly) is pretty convenient. I use this mount attached to a RAM Mounts arm/ball so it can pivot out of the way as needed.
What mount did you use? I like that. I think I can make out the word Trio? It would blend in with the white cab of my truck too.
Trio Flat Mount.
They have the magnet mounts. This is using the magnet mounts and can handle doing 70+ in the desert so should be more than enough for everyone!
I quit Gaia due to issues with downloading maps. Now use OnX, less expensive also. And I prefer OnX route building tools, they seem to work better, for me anyway.
i have both Gaia and OnX and gave onX a go, but some issues:
for some reason I am very limited on how big of an area I can download for offline use, with high def map. I tend to download an entire area (when I did the Alaska and Arctic Ocean trip I downloaded the entire CA, OR, WA, BC, YK, NWT, AK, AB, MT, ID, WY, UT, AZ, and NV lol)
and i do my route building on the web app, and not just the trails but also all the paved routes, so I know where gas stations and other POIs are along the way. And because I plot the route for my convoy as well (since I’m the one doing route planning), it’s just easier to include the paved section as well so if people show up late they know where we will be. doing it on Gaia has became a second nature for me and I can do it very quickly.
plus all of my data from the past 8 years are in Gaia… would be time consuming to move over to OnX.
those are some reasons why I went back to Gaia, especially after having Starlink on the roof now. otherwise, I can’t really use my phone with Starlink when driving anyways… wireless carplay uses wifi signal and blocks wifi from starlink, and Im not a fan of plugging in my phone these days.
Was preparing to run the NVBDR solo and spent about 10 days trying to get maps into GAIA, complete fail. That was end of GAIA as my main app. Spent a couple days in a small-town library downloading into onX, it worked.
For me Gaia quit downloading maps, even though my iPad has plenty of free space. I was told to delete all my previous maps which I did, still had issues. Spoke to them at OL West a couple years ago and they said their map storage database had some problems and they were trying to fix it.
Also spoke to onX, they said there was no limitation on map downloads other than the amount of free space. I have over 105g of maps downloaded now.
Eight years is a lot of data; I only had 2 1/2 years in Gaia. It’s all still there for reference, just not paying for the subscription anymore. Glad it’s working for you; hope they get the map issue fixed.
And I am planning to get Starlink before next trip, so downloads won’t be as much of an issue.
