Has anyone modified their GFC Superlite subfloor for custom mount points instead of the standard mounting tracks?
I have a Rhino Rack pioneer platform and I dont have clearance under the rack to use the standard brackets. In order to get the tent as low as possible on the rack I would like to drill a hole through the tent subfloor and use a bolt facing upward that the bolt head slides into the rack channels and the threads are exposed on the inside of the tent. From there I would tighten with a washer and nut from the inside.
I did this on my previous roof top tent because the subfloor was a rigid single piece of wood. I dont have a Superlite in person to see if this would work or not. I know the tent is made of some honeycomb plastic base so any input would be greatly appreciated!
