T track nuts
Anyone know where you can get the T track nuts for cheap. $18 for 4 of them on GFC site seems to be kind of pricey.
Or if anyone has a DIY idea let me know.
https://www.gzila.com/products/1-4-20-track-nut
yeah thats not much cheaper since they dont come with bolts. but thanks
Remember that the bolts are specific to the application, they must be the correct length for what you are mounting. Too short and you won’t have enough thread to be strong, too long and the bolt will bottom out through the nut, damage your track and not hold what your mounting tight.
Shipping bolts with the nuts can give a false sense of security and are a waste if they don’t fit your application.
I ordered the 10-32 track nut from GZilla and they came with the 1/2" bolts as well, both of them say:
"Includes Hardware
Includes matching stainless steel 1/4-20 x 1/2" socket head hardware."
Do agree the bolt length is determined by the accessory, when I ordered the 3DPROTO Lab anchor point and meat hook they came with longer screws but no nuts.
GZilla shipment:
Also worth noting, those from Gazilla are 6061 aluminum. GFC’s are either aluminum or stainless steel, depending on size.
The aluminum ones often give slightly, and can even crack, depending on how tight you wrench them. I haven’t noticed the steel ones deform at all.
